It takes a considerable amount of time slogging through the looonnnnggg list of inventoried applications, to Suppress Applications. After all that work, there doesn't seem to be a way to capture all that effort via export. So the next time you need to do it, set aside hours of time to do it aaaallllllll over again.
Please give us a way to export/import Suppressed Applications.
I'll submit a feature request..will post link in a sec...
EDIT] [https://jamfnation.jamfsoftware.com/featureRequest.html?id=1105
Don
Be the first to reply!
