JSS Database Size
  • January 3, 2012
  • 15 replies
  • 68 views
Hi All
Just wanted to know if this is normal or not, or JSS database is around the
52G mark, we are currently managing around 250 Macs via Casper.
This looks really large to me, is this normal?
Thanks
Abz
golbiga
Forum|alt.badge.img+21
  • Employee
  • January 3, 2012
That's pretty big, we have over 1400 macs in Casper and my Database is only 234mb. How often are you updating inventory of these machines?
  • January 3, 2012
Updating it every hour... I guess that would be the problem!
Any ideas how i'd trim down the database size?
  • January 3, 2012
What would be the recommended interval for the inventory look up?
golbiga
  • Employee
  • January 3, 2012
That will definitely cause you to have 52gb. We only do an update once a week - if I need to grab an updated inventory for some reason I'll just so via Casper Remote.
Settings -> Flush Database Logs might help.
  • January 3, 2012
thanks will give that a go! :)
  • January 3, 2012
Mine topped out at 17GB for ~100 machines before I realized that some of the tables were getting huge. I think the plugins.myd was over 12GB. I turned off collecting plugin data, shortened the retention window and it's now about 5GB.
If your JSS is running on a Mac, here's how you can start with some detective work:
Find the collective DB size:
sudo du -hd1 /private/var/mysql/jamfsoftware
Sort the DB files by size
sudo ls -la /private/var/mysql/jamfsoftware | sort -k5,5rn
  • January 3, 2012
My plugins.myd is 43G hugggggeee!, how did you turn of the collection of plugins data?
golbiga
  • Employee
  • January 3, 2012
Settings -> Inventory Options -> Inventory Collection Preferences -> Collect Plugins.
  • January 3, 2012
thanks!
  • Employee
  • January 4, 2012
I had the same issue that required me to disable the plugins table.
Every time the machines did a inventory, It detected that every single plugin on the machine had been removed and re-installed, So the table got very large very quickly.
Its still disabled because i have not found a fix yet.
John
  • January 4, 2012
Once I turned it off, I just let the data expire. I'm not a SQL expert and Jamf woudn't support dropping the plugins table. So, after turning it off and after the retention length was met (6months) the the JSS started flushing the plugin data, but it doesn't happen overnight.
  • January 4, 2012
Thanks, I may give that a try, also an odd thing i noticed was that every few days I cant connect to the JSS
When this happens ive tried restarting the tomcat service, but still cant connect, im thinking that this could be because of the database,
but the weird thing is the moment i restart the Server everything works fine again
  • February 17, 2012
Here are two MySQL commands that will give you more insight regarding the size of your database as well as each individual table:
NOTE: These are SELECT queries, and do not change or modify your data in any way.
Database Size Query:
SELECT table_schema "Database", ROUND(sum( data_length + index_length ) / 1024 / 1024, 3) "Database Size in MB", ROUND(sum( data_free )/ 1024 / 1024, 3) "Free Space in MB" FROM information_schema.TABLES WHERE table_schema = "jamfsoftware";
Table Size Query:
SELECT TABLE_SCHEMA AS 'Database', TABLE_NAME AS 'Table', CONCAT(ROUND(((DATA_LENGTH + INDEX_LENGTH - DATA_FREE) / 1024 / 1024),2)," MB") AS Size FROM INFORMATION_SCHEMA.TABLES where TABLE_SCHEMA like '%jamfsoftware%';
How do you get to MySQL to run these queries?
From terminal: mysql -u root
Then just enter either of the queries above to get your information.
You could also search for specific tables by doing the following from the terminal (NOT MYSQL):
mysql -u root -e "SELECT TABLE_SCHEMA AS 'Database', TABLE_NAME AS 'Table', CONCAT(ROUND(((DATA_LENGTH + INDEX_LENGTH - DATA_FREE) / 1024 / 1024),2),' MB') AS Size FROM INFORMATION_SCHEMA.TABLES where TABLE_SCHEMA like '%jamfsoftware%';" | grep plugins
This command will show only lines that contain "plugins" in them.
Hope this helps people with their database maintenance!
-Josh
  • July 13, 2012
Thats nothing ! My jamfsoftware MySQL database is 535 Gigs! It's causing a few issues backing up the database to move it though!
  • July 13, 2012
Also look at your log retention. Most places don't need logs older than 2 weeks. Have a look at automatically culling those.
