I have never had the privilege to use/image one of the older Airs or one of the new airs. We are currently looking at these as possible student laptops. Since they do not have ethernet, what is going to be the best way to image them with Casper?
Karl H. Hehr
Technology/Curriculum Director
South Hamilton CSD
www.s-hamilton.k12.ia.us
515.827.5418 (W)
515.708.3379(C)
515.827.5368 (F)
Luddite by Degrees
1) Anything that is in the world when you're born is normal and ordinary and is just a natural part of the way the world works.
2) Anything that's invented between when you're 15 and 35 is new and exciting and revolutionary and you can probably get a career in it.
3) Anything invented after you're 35 is again the natural order of things --- Douglas Adams
I use a Lacie hardrive with multiple partitions.
One partition is a simple small bootable OS
One partition is a JSS repo
Boot to the external OS and run imaging from the repo. After reboot be sure to run recon and all is well.
Nick Caro Senior Desktop Support Administrator
The new ones come with a thumb drive right, to restore the software with? You could sync the JSS to an external drive and boot from it and have Casper Imaging run from the external.
Hi Karl,
I recommend using the Apple USB Ethernet adapters. Just be sure to enter
them as Removable MAC Addresses in your JSS (Page 178 in the Casper Suite
7.3 Administrator's Guide - link below).
Hi all,
Sorry about the half-message. Too many windows open and my keystroke went
to the wrong app!
Here's the link for the Casper Suite 7.3 Administrator's Guide...
http://jamfsoftware.com/libraries/pdf/products/documentation/Composer_7.3_Do
cumentation.pdf
I hope it's helpful.
-- Miles Leacy
Technical Training Manager
Mobile +1 347 277 7321
miles at jamfsoftware.com
JAMF Software
1011 Washington Ave. S
Suite 350
Minneapolis, MN 55415
Office: (612) 605-6625
Facsimile: (612) 332-9054
US Support: (612) 216-1296
UK Support +44.(0)20.3002.3907
AU Support +61.(0)2.8014.7469
http://www.jamfsoftware.com
Slightly off topic. The MacBook Air does not have a Kensington Lock slot for security. Not sure how that plays into providing them to your students.
Thanks
Allen
