"Checking for policies"
  • August 5, 2013
  • 8 replies
  • 28 views
Hello JAMF Nation. I'm new to Casper and was wondering if there is a way to disable the "Checking for policies" pop-up when logging in and/or logging off?
Best answer by armando
JSS Webpage>Settings>Computer Management Framework Settings>Login/Logout Hooks> Uncheck Display status to user during login and logout.
  • August 5, 2013
Been a while since I've modified this setting, but I believe this is what you are looking for:
Log into JSS, Click on Settings, Computer Management Framework Settings, Login/Logout Hooks, "Create login and logout hooks" and "Perform login actions in background" need to be checked.
armando
  • August 5, 2013
  • August 5, 2013
Well, I almost had it. I was about 10 pixels away from the right answer!
  • August 5, 2013
If you disable the "Display status to user" option, its also a good idea to check on the "Perform login actions in background" option, otherwise you run the risk of login policies locking up the screen as a policy runs with no indication that something is happening. So in that sense, you are also right bajones :)
  • November 15, 2013
Thank you guys for the response.
  • November 15, 2013
  • November 18, 2013
We don't have login/logout hooks enabled so we can't disable the "Display to users" piece. We see this notification pop-up between FileVault authentication, and full login. Offline (i.e. no contact to the jss) this takes longer... a minute or two, and beachballs. Any other thoughts?
  • November 27, 2013
Can the message be changed to say something more helpful? I've had users tell me that they thought they had a virus and unplugged their machine. "Checking for Policies" is not very friendly.
