Hello,
Not sure where to begin with this one. I have a mobile filter package that we are pushing out to all of our student Macs. I've looked at the chart and logs and see a hundred or so "Failed" reports, out of about 1600. That didn't seem too bad, so I started looking at the reports. The first dozen I opened showed the package as successfully downloading and installing. The failure came at some point during the Recon process. Either at the beginning, at the "Retrieving inventory preferences from https://jss-01.ccsd93.com:8443/..." or at the end with some form of "Error running recon: Connection failure: "The host jss-01.ccsd93.com is not accessible."
My first question is: Is it possible to not show Recon failures as "Failures"? Everything else processed successfully.
Second: Any idea why our JSS is sometimes inaccessible? We did update the server to 9.11. We are running our JSS on a Linux server that has been kept updated. Are there updated system recommendations for 9 on Linux that I did not notice?
Thanks, Tim
