Enrollment Profile with iOS7
  • July 22, 2014
  • 10 views
Hi guys, I'm trying to create an enrollment profile to use with Apple Configurator. Target iOS Version doesn't show iOS7 (shows only iOS 4 to 6). We are on v9.3, what am I missing ? Thanks.
Best answer by bountyman
Thanks. I unchecked the option since I want to use Apple Configurator and I was able to download the 'trust profile'.
  • July 22, 2014
I believe you only need to set the target version if you are planning to use iPhone Configuration Utility for the enrollment. If you aren't, then uncheck that box and the target version drop down will disappear.
  • July 22, 2014
