For background, we are using DEP and want to force a password change to the users account once we deliver the machine. So we create the account out of the box, the machine logs in and policies apply, and then when we deliver the machine they have to change their pw.
The policy runs a simple script:
sudo pwpolicy -u $USER -setpolicy "newPasswordRequired=1"
The script works great and when you reboot the user is forced to change the password. The problem is that we are getting popups at login for "talagent wants to use the "Local Items" keychain," "Messages Agent wants to the use the "Local Items" keychain," and "cloudpaird wants to use the "local items" keychain."
This is a persistent error until removing ~/Library/Keychain/reallyLongString which isn't a viable solution, especially since the string is different every time.
Are other people seeing this issue? Or are you forcing a pw change via a different method?
