Is there any info available on this? I need to deploy a remote JDS and CentOS is the only Linux available to me in that environment.
I'm working on this right now. I've gotten about half way through changing the correct items. Right now I've got it so the script will run. The problem is the program that does the actual enrollments is a binary (I think) and has version checking logic as well. I'm impressed with how difficult this is, given that the JSS installs on CentOS just fine...
I made this, please go vote it up if you like the idea https://jamfnation.jamfsoftware.com/featureRequest.html?id=2126
I am not really familiar with these Linux variants..
What - if anything - is the advantage of doing this ?
( Not wanting to start a platform war or anything.. In this case I really don't know why one one system might be considered better then another.. It's not an area that I have researched )
I would like to get some idea why you think it's worth the bother..
Centos is derived from Red Hat source code, but it's fully open-source as opposed to RH's subscription-based model. I think that's the main reason it's so popular - we use Centos on several servers here for different tasks, and I'll probably be going to Centos for our JSS migration. (I did my early testing on Centos, and it worked great after just a few tweaks.)
CentOS is a truly stable platform to use, but I see the problem being there is no good documentation associated with the JDS or how to "tweak" it for most admins.
Most documentation is really superior with JAMF, this is the one spot I see failing. Just my $.02
@PeterClarke for me its not so much a personal preference, its what we use here so it's what I need it on :) or buy another OS X device for this as it's for a kit we use to move around with for conferences a cents VM would be way easier.
How is it checking the OS? You might just be able to change the text of the /etc/redhat-release file.
CentOS:
CentOS release 6.4 (Final)
RHEL:
Red Hat Enterprise Linux Server release 6.4 (Santiago)
@jack_bishop][/url][/url has it right. Run this:
echo "Red Hat Enterprise Linux Server release 6.5 (Santiago)" > '/etc/redhat-release'
I had to run the echo command as root. Sudo didn't work for some reason, so I did "sudo su".
You may also have to install dmidecode (it wasn't included in our minimal centos image):
sudo yum install dmidecode -y
I now have a JDS up and running on centos. Those two commands were the only special prep the server required.
