So, I got bitten by the Mojave system user template permissions change/problem. The offending policies have been disabled and will be replaced so the problem isn't getting any worse, but is there any way to restore the original Apple made template on affected machines without completely rebuilding them? Given the multiple template tweaks accumulated over the years simply deleting only the changed files is impractical.
Restoring original Mojave user template
