We were unable to efficiently use MCX (in Casper) to manage dock items/order so we found a few alternate methods. As far as I know, Casper is not able to perform dock arrangement in MCX.
Which OS(s) are you applying the dock to?
With Casper 8.4 you can create "deployment profiles" that set up just like an iOS profile and set your order that way.
Using a Casper "dock item" policy does not set any order to your dock. If you run the policy on all of your machines at the same time, you will get similar results, however if you run the policy on 10 machines then wait an hour and run it on ten more, you will most likely get a very different order.
Another possibility is to build the dock on a test machine and capture it using composer with the "user environment" option. This will capture your order as well.
Depending on when you want to apply dock changes in relation to user creation there are other possible issues that can arise.
Hope this helps a little!
Pat B.
Springfield Public Schools
Here is what I have been working on getting the docks to work with MCX and dockutil. So far, the results have been promising.
MANAGING OS X DOCKS
(SNOW LEOPARD AND LION)
VIA
JAMF, MCX, AND CLI
by
Jacob Salmela
2012
Technology Support Specialist
for
Hopkins High School
Minnetonka, MN
Last updated: 15 June 2012
Requirements
00. Composer Mac (The Mac used to create packages and scripts)
01. Test Mac (The Mac used to test the packages and installs prior to full-scale deployment)
02. dockutil code https://github.com/kcrawford/dockutil/blob/master/scripts/dockutil
03. Familiarity with OS X
04. Intermediate experience of the command-line interface (CLI) and bash scripting
05. Familiarity with the Casper Suite and JSS
Conceptual Overview
00. Download and install dockutil
01. Create dockutil install package via Casper Composer
02. Deploy package to computers via Casper Remote
03. Create bash script that creates a base dock
04. Create MCX to make the dock immutable
05. Modify the dock over time using Casper Remote or on the local computer using Terminal
Acquire dockutil Source Code
00. On the Composer Mac, go to https://github.com/kcrawford/dockutil/blob/master/scripts/dockutil
01. Highlight and copy the script
Begin a Normal Snapshot in Casper Composer
00. On the Composer Mac, open Casper Composer
01. Choose Normal Snapshot, then click Next
02. Give the package a meaningful name using a naming convention, then click Next.
Note: If there is no naming convention in place, start one, now!
Create the dockutil Application when the Before Snapshot is Complete
00. Open Terminal when the before snapshot is complete
01. Use vi or another text editor to create a new document in /usr/bin called dockutil
02. Paste the code into the document
03. Save the document
04. Type ```
sudo chmod 755 /usr/bin/dockutil
``` then press Enter
Capture the dockutil application in the After Snapshot
01. Click Create Package Source
02. Click Build as DMG
03. Choose a location to save it, then click Save
04. Make a backup copy
Upload the .DMG to Casper Admin
00. Upload the .DMG to Casper Admin
Deploy the .DMG to the Test Mac via Casper Remote
00. On the Composer Mac, open a new Casper Remote window
01. Check the box next to the Test Mac
02. Click the Packages tab
03. Check the box next to the dockutil package that was uploaded previously
04. Click Go
Verify that the dockutil Installed in the Correct Place
00. On the Test Mac, open Terminal
01. Type ```
ls -l /usr/bin/dockutil
Note: If dockutil install correctly, there will be a listing for it after
entering this command.
Run a Simple Command to Ensure dockutil Works Properly
02. Click the Advanced tab
03. Type ```
dockutil --add /Applications/Calculator.app
``` in the Run Command field
04. Click Go
Note: If dockutil works correctly, the Calculator app will appear on
the logged in user’s dock.
Create a Script that will Set the Default Apps that should be on a User’s Dock
00. On the Composer Mac, open Terminal
01. Create a new script using vi or another text editor
02. Create a script to set a user’s base dock, similar to the one below:
Note: This example script removes all dock items and then adds each new
item in the order it will appear on the dock, hence the sequential commands.
Note: This example script will run as root so the su command is being
used. Replace the user david_hayter for the correct username the dock is being made for
Note: The defaults commands are not required, but they help create
an aesthetically pleasing dock.
#This script runs dockutil to create a dock for the admin user: david_hayter
#The dock will appear in order the commands are run
#Substitute david_hayter for the username the dock is being made for
#If this is run as root via Casper, the user’s password is not required
#This script can also be pasted into an ARD UNIX command and run as root
su david_hayter -c "/usr/bin/dockutil --remove all"
su david_hayter -c "defaults write com.apple.dock persistent-apps -array-add '{tile-data={}; tile-type="spacer-tile";}'"
su david_hayter -c "/usr/bin/dockutil --add /Applications/Safari.app"
su david_hayter -c "/usr/bin/dockutil --add /Applications/Firefox.app”
su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/System Preferences.app"
su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/Terminal.app"
su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/Disk Utility.app"
su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/Activity Monitor.app"
su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/Console.app"
su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/Hopkins Software Self Service.app"
su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/Recon.app"
su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/AppleScript Editor.app"
su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/Java Preferences.app"
su david_hayter -c "/usr/bin/dockutil --add /Applications/TextEdit.app"
Add some optional logic to improve the script’s adaptability and longevity:
Note: The case command can be used to add different dock items
depending on certain criteria. In the example below, it installs either the System Profiler, or System Information depending on the OS version.
Note: The test command is also used to see if an app exists and adds it
if it does.
#!bin/bash
#A case statement can be used to install either the System Profiler (in 10.6) or the System Information app (in 10.7)
#This bit of logic makes the script adaptable to two different OS’s
osversion=`sw_vers -productVersion`
case $osversion in
10.6.[0123456789]) su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/System Profiler.app";;
10.7.[0123456789]) su david_hayter -c "/usr/bin/dockutil --add /Applications/Utilities/System Information.app";;
esac
#Another bit of logic uses the test command to see if the Chrome directory exists. If so, it adds it to the dock, otherwise it does nothing
test -d /Applications/Google Chrome.app
if [ $? = 0 ];then
su david_hayter -c "/usr/bin/dockutil --add /Applications/Google Chrome.app"
Create an MCX Profile to Test the Script and MCX Settings
00. On the Composer Mac, open the JSS Web-interface
01. Navigate to Management > Managed Preferences > Create Managed Preference Profile
02. Enter a Display name
03. Click the Scope tab
04. Add the Test Mac to the scope
05. Click Save
Create an MCX Setting and Profile to Make the Dock Immutable (To everyone except you!)
01. Navigate to Management > Managed Preferences > Create Managed Preference Create from Template
02. Expand com.apple.dock
03. Click Create next to the Changes Disabled preference
04. Change the value to true
05. Add the preference the profile created in the last step
06. Click Save
Note: The dock will be immutable in the GUI for any user, but items can
be added, moved, or removed from the dock via the CLI. dockutil commands can be sent via Casper Remote, ARD, or locally in Terminal.
Bonus: Setting the dock as immutable via MCX provides a consistent dock
across the organization. At the same time, dockutil provides the ability to modify the dock, even though it is considered “immutable”.
Bonus: The commands can be sent if the user is logged in or out. If the user
is logged in, their dock will restart with the changes made by the command(s). If they are logged out, the new dock will appear at the next login.
Note: If the commands are run locally in Terminal, it will prompt for the
user’s password.
Appendix A: List of Useful dockutil Commands
00. Add a dock item
01. Remove a dock item
dockutil --remove ‘Calculator’
02. Add a dock item to the Apps section (left-side of dock)
dockutil --add /Applications/Calculator.app --section apps
03. Remove a dock item to the Others sections (right-side of dock)
dockutil --remove /Applications/Calculator.app --section others
04. Add a dock item that replaces an existing item
dockutil --add /Applications/iMovie.app --replacing ‘GarageBand’
05. Move a dock item to another location
dockutil --move ‘Calculator’ --position 7
06. Move a dock item to the beginning of the dock
dockutil --move ‘Calculator’ --position beginning
07. Add a folder to the Others side of the dock
dockutil --add ~/Downloads
08. Add a folder to the Others side of the dock with the grid-style
dockutil --add ~/Downloads --view grid
09. Add a network share to the Others side of the dock
dockutil --add afp://server.domain.com
10. Remove an item from all user docks
dockutil --remove ‘App Store’ --allhomes
11. Add an item right next to another one without knowing the location
dockutil --add /Applications/Firefox --after ‘Firefox’
A few tips :)
You shouldn't have all those su -c's and you dont need them.
Dockutil lets you specify the dock you want to change like so:
dockutil --add /Applications/Utilities/Grapher.app /Users/david_hayter/Library/Preferences/com.apple.dock.plist
Just putting /Users/david_hayter is supposed to work as well but it looks like it might be broken in 1.1.2. I have used it before but it is not working on this iMac at the moment... :(
You could even do something like
mydock="/Users/david_hayter/Library/Preferences/com.apple.dock.plist"
Up at the top to make things a bit more readable later on:
dockutil --add /Applications/Utilities/Grapher.app "${mydock}"
For the second script you don't need all those numbers in your case statement.
10.6*)
10.7*)
Will work just fine (incidentally so would [0-9]).
Here is a nicer way to do the Chrome bit as well.
if [[ -d "/Applications/Google Chrome.app" ]]; then
dockutil --add "/Applications/Google Chrome.app" /Users/david_hayter/Library/Preferences/com.apple.dock.plist
and we can even make that a tad more clever with simply this:
[[ -d "/Applications/Google Chrome.app" ]] && dockutil --add "/Applications/Google Chrome.app" /Users/david_hayter/Library/Preferences/com.apple.dock.plist
P.S. for simple drag installs and ESPECIALLY things like dockutil (1 small file), Composer's "Monitor Filesystem Changes" package type works wonders and would save you a TON of time.
P.P.S. check this out it is awesome!! :D
http://mywiki.wooledge.org/BashGuide/
