Hi All,
I am a new user to Casper and had a quick query.
I have packaged up Symantec Antivirus for OS X version 10. Which seems to
work fine. When I deploy it though the app works fine but live update and
the scheduler fail with errors. Has anyone packaged this up successfully or
had issues similar to mine when doing it?
Regards,
Chris Lang
Chris Lang
Support Services Advisor
Client Services
Information Technology Services
Phone: +61 3 9919 2735
Fax: +61 3 9919 2785
Mobile: +61 411 259 496
Email: Chris.Lang at vu.edu.au
