How to display user's IP address on the client machine
  • July 22, 2014
  • 43 replies
  • 239 views
We're a pretty large organization, and when a user calls our help desk one of the first things they ask for is the IP address of the machine they're on. A lot of our Mac users don't know how to get that information, even though it can be explained to them a better way would be to have a big button in Self Service that says "What is my IP Address" or something.
Casper already knows each user's IP address. Is there a way to leverage that information into a script that displays it for the end user when they click the button in self service? I already have a script that uses jamfhelper to put up a hud window type, I can modify it to display the user's IP address, I assume, if I can find a way to get the IP address in the first place. And possibly to copy it to the user's clipboard when they click an OK button in the window that pops up.
And before you ask, no, the help desk does not have access to casper and that will probably change in the future, but for right now I need a way to utilize Self Service to display an end user's IP address for them. Any ideas?
Best answer by PeterG
Couldn't resist. did this today.
this will give you consecutive popups for any active IP addresses.
I use detecting a subnet to tell me if that interface has an IP.
#! /bin/bash
# Name: MyIP.sh
# Version:  1.0
# Author:  Peter Gawlocki
SUBonTB=`networksetup -getinfo Thunderbolt Ethernet|grep Subnet| wc |awk '{print $1}'`
SUBonWiFi=`networksetup -getinfo Wi-Fi|grep Subnet| wc |awk '{print $1}'`
SUBonEnet=`networksetup -getinfo Ethernet|grep Subnet| wc |awk '{print $1}'`
if [ $SUBonEnet = 1 ]
    then
        ReportEnetAddress=`networksetup getinfo Ethernet|grep IP| awk '{print $3}'`
        /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -icon /System/Library/PreferencePanes/Network.prefPane/Contents/Resources/Network.icns -title "Your IP Address" -description "Your current IP address for Ethernet is: "$ReportEnetAddress -button1 "Ok" -cancelButton 1 -timeout 10;
if [ $SUBonWiFi = 1 ]; then
        ReportWiFiAddress=`networksetup getinfo Wi-Fi|grep IP| awk '{print $3}'`
        /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -icon /System/Library/PreferencePanes/Network.prefPane/Contents/Resources/Network.icns -title "Your IP Address" -description "Your current IP address for Wireless is: "$ReportWiFiAddress -button1 "Ok" -cancelButton 1 -timeout 10;
if [ $SUBonTB = 1 ]; then
        ReportTBENAddress=`networksetup getinfo Thunderbolt Ethernet|grep IP| awk '{print $3}'`
        /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -icon /System/Library/PreferencePanes/Network.prefPane/Contents/Resources/Network.icns -title "Your IP Address" -description "Your current IP address for Ethernet is: "$ReportTBENAddress -button1 "Ok" -cancelButton 1 -timeout 10;
We have it up in the menu bar on all our machines.
http://www.monkeybreadsoftware.de/Software/IPinmenubar.shtml
  • July 22, 2014
@activitymonitor unfortunately that would involve distributing it to all our mac clients, then instructing the end users on what to look for, and then instructing the help desk to ask for the user to get it from that menu item. It's not really practical for our purposes, and would most likely cause more confusion than ever. Our help desk doesn't really have a good grasp on English or on Macs, so I'm trying to keep it as simple as possible so that the help desk doesn't need to learn anything new, and the user has an easy option using a mechanism they're already familiar with, namely Self Service.
jhbush
Forum|alt.badge.img+27
  • July 22, 2014
@znilsson, this is one I use from Rusty at PSU.
#Display IP Address and Hostname of Computer
#Written to be used with Playtpus to create a app.
#Written by Rusty Myers
#Functions
function testinterface {
    en0test=`ifconfig en0 | grep -q 'inet ' && echo en0`
    en1test=`ifconfig en1 | grep -q 'inet ' && echo en1`
    # echo $en0test
    # echo $en1test
    if [ "$en0test" == "en0" ]
        then
            activeinterface=en0
    elif [ "$en1test" == "en1" ]
        then
            activeinterface=en1
            activeinterface=None
function displayip {
if [ "$activeinterface" == "None" ]
    then
        ipaddress="None"
        ipaddress=`ipconfig getifaddr $activeinterface`
function displaydialog {
echoserial=`/usr/bin/osascript << EOT
tell app "System Events"
     Activate
     display dialog "Your IP address is $ipaddress. Your computer name is $computername" buttons "OK" default button 1 with title "IP Address and Computer Name"
end tell
EOT`
echo $echoserial
#Variables
computername=`scutil --get ComputerName`
testinterface
displayip
displaydialog
Forum|alt.badge.img+19
  • July 23, 2014
I'd probably write a script that checks for ethernet enabled and pulls the IP address and hands it to jamf helper to display in a popup. Put it in self service and then ask the user to press the button.
If you wanted to get fancier you could use network setup to detect if they are on Ethernet, Airport, Thunderbolt Ethernet, etc... and pull the active one.
start with an If statement looking for ... networksetup -getnetworkserviceenabled Ethernet
to return Enabled.
then a ReportIpAddress=networksetup getinfo Ethernet|grep IP| awk '{print $3}' to get the numher
then send that info to jamf helper.
/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -icon /System/Library/PreferencePanes/Network.prefPane/Contents/Resources/Network.icns -title "Your IP Address" -description "Your current IP address for Ethernet is: "$ReportIpAddress -button1 "Ok" -cancelButton 1 -timeout 10;
  • July 23, 2014
Jason, thanks for the script. It returns the IP address correctly on devices that only have one NIC active, but on some systems, it returns the information twice. It appears it is drawing a dialog for each active network interface, but only provides the IP address of en0.
Have you seen that behavior? Any way to easily return the values of each active NIC?
  • July 23, 2014
#! /bin/bash
# Name: MyIP.sh
# Version:  1.0
    then
jhbush
  • July 23, 2014
@PeterG thanks for posting this. I added in the Display Ethernet my designers use.
#! /bin/bash
# Name: MyIP.sh
# Version:  1.0
SUBonDTB=`networksetup -getinfo Display Ethernet|grep Subnet| wc |awk '{print $1}'`
    then
if [ $SUBonDTB = 1 ]; then
        ReportTBENAddress=`networksetup getinfo Display Ethernet|grep IP| awk '{print $3}'`
        /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -icon /System/Library/PreferencePanes/Network.prefPane/Contents/Resources/Network.icns -title "Your IP Address" -description "Your current IP address for Display Ethernet is: "$ReportTBENAddress -button1 "Ok" -cancelButton 1 -timeout 10;
jhbush
  • July 23, 2014
@Kevin I use that script wrapped as an app on my NetBoot sets. @PeterG may be a better choice for Self Service.
  • July 23, 2014
Freaking fantastic. That is exactly what I needed, thanks so much. Confirmed it works using different interfaces and everything.
  • July 24, 2014
@jhbush1973][/url as I was describing what I wrote to Sunny, our other CCA, she said, "Why don't you wrap it and put it in their Applications folder?" heh... we are all on the same page.... love JAMF Nation.
I am looking to populate self service with as much helpful stuff I can... because I can't hire staff :-(
I use the subnet detect thing when I wrote another script for controlling which Thunderbolt Ethernet Adapter can be used with which computer.
Since our 'current' network security uses MAC address to allow/deny access I can't give out a TbEn adapter to a user and have them bring in a non-company computer and use the company adapter and get on the network.
The script compares the MAC address of the adapter to a plist that we 'hid' and uses jamf helper to display a message if a mismatch is found. It also shuts down the TbEn Interface to make it unusable. It is a launched that runs every 15 seconds. (checks if the TbEn interface pulls an IP) then Acts, if needed.
  • July 24, 2014
Interesting… I put this in Self Service and it works wonderfully.
However… on my Desktop–and so far ONLY on my Desktop, the results are returned as expected, but they are returned three times.
Any ideas?
  • July 24, 2014
Are your results exactly the same (wording)? (like Ethernet repeating 3 times?
If so, and you get ethernet three times... if you turn on WiFi also do you get: Alerts like this order... Ethernet, WiFi, Ethernet, WiFi, Ethernet, WiFi?
or Ethernet, Ethernet, Ethernet, WiFi, WiFi, WiFi, ?
Do you have multiple interfaces actively pulling IPs?
Since there is no loop in the script, it does not seem possible to run multiple times.
Is it added multiple times in the Policy?
  • July 24, 2014
Yes, exact wording three times. I have two NICs active and I get the results returned three times for each. If I run the script in Terminal, it only returns results once. Just as a policy does it behave this way…
Every other Mac I run it on in Self Service only returns results once. I have tried it on several Macs now - they all work fine. Same policy, pulling the same script.
  • July 24, 2014
Same here. I get a total of 4 pop ups-2 for each connected interface.
jhbush
  • July 24, 2014
Running this via Self Service works hit or miss right now and I'm not really sure why. The policy shows as succeeded, but the JAMF helper boxes don't show up.
Forum|alt.badge.img+31
  • July 25, 2014
Hi Everyone,
Saw this thread today and thought some cool stuff was going on so I marked it for later. I whipped up an example of how you can display all Network IP addresses to an end user. Just in case they happened to be connected to WiFi, their HotSpot, Ethernet, etc.
# dispaly information to end user
# set IFS for new line
# use unset IFS to reset it to default value
IFS=$'
# get list of networkservices exlcuding disabled services
NetServices=$(networksetup -listallnetworkservices | grep -v '*')
for service in ${NetServices} ; do
echo "${service} is currently assigned: $(networksetup -getinfo ${service} | awk '/IP address:/ { gsub("[a-z]", ""); print $3 }' | sed 's/://g')" >> /tmp/netinfo.txt
done
# applescript to display dialog
osascript <<AppleScript
tell application "Finder"
 activate
 display dialog "Your Network Information is:
  $(cat /tmp/netinfo.txt)" buttons {"OK"} default button 1
end tell
AppleScript
unset IFS
# clean our temp file
srm /tmp/netinfo.txt
What it looks like:
external image link
Unfortunately, I had a really hard time getting all that text to fit in my JAMF Helper examples. Like I said, not sure if this is even of interest to you all, but I figured if you displayed everything to an end user and they started reading off their IPs and services the Help Desk person would know what is best to connect to. Like if they happen to drag their service order to WiFi above Ethernet and the Help Desk person wants to remote in to install software, they would preferably want to do that over Ethernet.
Sorry for the pipes, my awk skills are slipping I had to pipe to sed to get rid of a pesky ":" that kept getting tossed in output. I also just loop through all Network Services that are currently enabled. That way you don't have to write specific code looking for specific network adapters.
EDIT - hooked up my hotspot to show how it will display multiple IPs when connected to multiple services, also should have mentioned I purposely disabled all my FW networking interfaces as a proof of concept so that is why they are excluded:
external image link
Hope this helps out
Thanks
Tom
  • July 25, 2014
I thought I'd throw in another variation here. This one uses bash arrays, will report on any hardware ports with active IP addresses and skip the rest for clarity, and uses cocoaDialog for the messaging, although in theory you could easily use AppleScript or jamfHelper with this just as well.
## Name:     show-my-ips.sh
## Path to cocoaDialog. Customize to your environment
cdPath="/path/to/cocoaDialog.app/Contents/MacOS/cocoaDialog"
## Get the Mac's name
MACNAME=$(scutil --get ComputerName)
IFS=""
## Place all hardware ports into array
while read port; do
    HWPORTS+=( "$port" )
done < <(echo $(networksetup -listallhardwareports | awk -F': ' '/Hardware Port/{ print $NF }'))
## Place all device ids into array
while read device; do
    DEVICES+=( "$device" )
done < <(echo $(networksetup -listallhardwareports | awk '/Device/{ print $NF }'))
## Loop over hardwareport array checking for active IP and add any to new array along with device IDs
for ((i = 0; i < ${#HWPORTS[@]}; i++)); do
    IP=$(ipconfig getifaddr ${DEVICES[$i]})
    if [[ ! -z "$IP" ]]; then
        IPADDRESSES+=("${HWPORTS[$i]} (${DEVICES[$i]}):        ${IP}
done
## Reset IFS to space
IFS=" "
## Clean up final array for message
ACTIVEIPS=$(echo -e "${IPADDRESSES[@]}" | sed 's/^ *//')
MESSAGE="The following are details about your computer:
Mac Name:
${MACNAME}
Device Name (Port):     IP Address:
${ACTIVEIPS[@]}"
"$cdPath" msgbox
    --title "My IP Addresses"
    --text "Details about your Mac"
    --informative-text "$MESSAGE"
    --button1 "   OK   "
    --icon network
A screen shot of what it looks like. It would normally report the Mac name, but I removed that for the image.
external image link
  • July 25, 2014
I think IPMENUBAR works great. sure, there is the task of distributing it and executing it on the endpoint, but its very simple and in the users menu bar all the time. there is not much instruction the user will need other than look on your top right for a number that begins with your x.x.x.(depending on the class network you are using) - all my users (even the technically challenged ones) can see this number very quickly.
jhbush
  • July 25, 2014
@mm2270 thanks for this version do you need to add an ```
if [ "$rv" == "1" ]; then
    echo "User said OK"
exit
  • July 25, 2014
@jhbush1973 - It depends. Since my message only has an "OK" button, I'm not particularly concerned about whether a user clicked it or not. (they would have to click it eventually)
I'd only care if there was more than one button and I needed to take some action or report on what button was clicked.
That said, its usually a good idea to include an exit in a script so we could include exit or exit 0 at the end.
jhbush
  • July 25, 2014
@mm2270 the reason I ask is the script exits 1 and I thought maybe JAMF would see it as a failure.
  • July 25, 2014
Heh... I like youze guys solutions better... <snag>
This place is great... any of you scripting whiz types want to assist with this one? It's driving me nuts!
See https://jamfnation.jamfsoftware.com/discussion.html?id=5238 and https://jamfnation.jamfsoftware.com/discussion.html?id=11226
  • July 25, 2014
@jhbush1973 - I see what you mean. That's cocoaDialog reporting that the "OK" button was clicked, not the exit code for the script. I think there's a silent flag in CD that we can throw in there that will make the "1" not show up, but either way, I don't think Casper would see that as a failure since its not the actual exit code. At least I would hope not. That would be just as bad as looking for keywords like "error" ;)
I guess the best test would be to run it from Self Service and see what the end result shows as, as in Failed or Succeeded, etc.
  • July 25, 2014
Ok, found it. Had the wrong term though. Its called "--quiet" So just add this to the end of the cocoaDialog section and the "1" will not show up in stdout, in case its a concern. Not sure if the older version of CD has this, but the latest beta does.
Updated code for the cocoaDialog section would look like this-
"$cdPath" msgbox
    --button1 "   OK   "
    --icon network **
    --quiet**
jhbush
  • July 25, 2014
@mm2270 thanks for pointing that out. One thing I noticed is that it displays the info twice using Self Service. Run by itself the script exits showing the information once. I'm running the beta and I couldn't find that --quiet trigger in the documentation. Good news is that without the --quiet it exits successfully.
