Web clips are links to websites, placed into Self Service and visible on the left pane. They can either open the webpage in the Self Service app, or the default Mac browser. The reason I say that is because I'm not sure what you mean by "installable"?
If you configure web clips into Self Service, they will show up in everyone's Self Service app.
Computer Managemen >> Self Service Plugin-ins >> New
That is where you set them up. Is this what you're asking?
Here's a link with more info:
Not quite. I'm referring to mobile management... I don't think I have a left pane in the Self Service iOS app.
Ah sorry, missed "mobile". Apologies. You're right.
Whoops, I found it. You can put them in a category from inside Configuration Profiles and set them to Make Available instead of Automatically Install.
Yes, now that I took my CCT I now know that is an option for iOS. Glad you found it...
