migrating JSS to new server - tip
  • August 13, 2008
  • 0 replies
  • 1 view
Just double check that your distribution point is created and permissioned
correctly after the move, especially if your JSS is also a distribution
share.
I recently moved from a G5 Desktop to a Intel Xserve. The process went so
smoothly that I felt I had to check all the pieces (Casper Remote, Casper
Admin, JSS) over three times.
Jason
