Hi all
Was wondering if someone might be able to help.
I have machines booting from a diskless NetBoot image created with apples imaging tools. (Automator action doesn't work)
This automatically logs in as a account called local-admin, launches Casper imaging and goes through the imaging process.
At the very end before the machine reboots it says
**Connection Error
Connecting to https://xxxxx:8443/ :42**
I am using a launch daemon and script as a work around to recognise this in the system log and to force reboot after 5 minutes.
I have always had this problem and support couldn't help because they didn't know what is causing this.
If anyone else has had this problem please can you let me know because i fear my mental state is turning quite funny :(
sorry my fault.
NetBoot Image had proxy pac set. Added exclusions in the proxy pac file and works without any problems now.
Fixed
https://jamfnation.jamfsoftware.com/discussion.html?id=554
So the combination of packages was causing this issue?
