Casper reporting can't find package
  • October 9, 2013
  • 0 replies
  • 4 views
ImAMacGuy
Forum|alt.badge.img+23
I'm getting tons of errors from the JSS that it can't find the packages to install...yet I can check the share and they are there. I can even launch them (so I know they aren't corrupted). And some even go through w/o issue. At first I thought it was possibly trying to map teh share drive as /CasperShare 1... but that doesn't seem to be the case.
An error occurred while running the policy "Upgrade Flash" on the computer "usnycmc311021". Actions from policy log: Executing Policy Upgrade Flash... Error: The package (Install Adobe Flash Player.pkg) could not be found. Running Recon... Retrieving inventory preferences from https://server:8443/... Locating accounts... Searching path: /Applications Locating package receipts... Locating software updates... The complete policy log is available in the JSS at: https://server:8443//policies.html?id=7548&o=l Computer ID: 660
