My non-administrative JSS users started getting the above error after upgrading the JSS to 9.62 (from 9.5)
My boot disks are running OS 10.9.3 with Casper Imaging 9.3. According to the release notes, 9.62 should be compatible with Casper Imaging 8.6 and later.
For several of my JSS users (all LDAP), I had only "Use Casper Imaging" checked in the Casper Imaging section. To "fix" this error, I also had to enable privileges for BOTH "Customize a Configuration" and "Store Autorun Data". I don't really want to do this for everyone, and I don't really want to rebuild all of my boot media. Anyone else seeing this?
