A 'case' statement might do the trick here, although I'm not so good at writing those.
Another way may be to use the 'or' operand in your conditional statement. Something like this, though I can't test this out, so I'm not certain this will work-
SSID=`/System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Resources/airport -I
| grep ' SSID:' | cut -d ':' -f 2 | tr -d ' '`
if [[ $SSID = "RLSPOT001" || "RLAVID001" || "RLSHEE001" || "RLGUES001" || "RLBGAS001" || "BTFON" ]]; then
/usr/sbin/networksetup -setairportpower en1 off
There are likely much more elegant ways of doing this though.
First, finding your SSID is way easier with networksetup. Before that though, you're going to need to detect which interface is your Wi-Fi interface. On a MacBook Air, it's going to be en0. On anything with built-in ethernet it's going to be en1 (or even en2 on a Mac Pro with dual ethernet NICs)
Detect your wi-fi interface with this:
wifi=`networksetup -listallhardwareports | awk '/Hardware Port: Wi-Fi/,/Ethernet/' | awk 'NR==2' | cut -d " " -f 2`
Then find your SSID with:
SSID=`networksetup -getairportnetwork $wifi | cut -d " " -f 4`
Lastly, case statement for the SSIDs you want to restrict. Here's your full script:
#Detect our Wi-Fi interface
#Detect our connected SSID:
ssid=`networksetup -getairportnetwork $wifi | cut -d " " -f 4`
case $ssid in
RLSPOT001|RLAVID001|RLSHEE001|RLGUES001|RLBGAS001)
networksetup -setairportpower $wifi off
esac
I haven't tested a lick of it so test test test.
Didn't think of it, but Jared is correct. If you have a mix of Mac types you need to make sure you know which interface WiFi is mapped to for your script to work. If, on the other hand you have all MacBook Pros or all iMacs, e.g, and it will stay that way, the way you have it is fine. Its probably still safer to detect the WiFi interface though.
Thanks guys
i also need to allow for a dns bug and need it to work for 10.6 "airport" and wi-fi 10.7+
airport=/usr/sbin/networksetup -listallnetworkservices | grep -E '(Wi-Fi|Airport)'
airport=`/usr/sbin/networksetup -listallnetworkservices | grep -E '(Wi-Fi|Airport)'`
All I got back was "Wi-Fi" (on 10.8.1). I would think you're trying to return the actual interface (en0 vs en1) or am I misunderstanding something?
In 10.6.x it was listed as "AirPort", not "WiFi". I think that's what he's referring to.
Thanks this is what i have below and works for me.
I think i will just leave it
# HISTORY
# Version: 2.2
# - Created by Tim Kimpton on September 12th, 2012
# Stops network bridging turning the relevant network interface off and on
# SETTING THE ENVIRONMENT VARIABLES
# Get the wirless or airport hardware port
# Current Logged in User
consoleuser=`ls -l /dev/console | cut -d " " -f4`
# Get the SSID
# See if ethernet if active and if it is then we need to turn OFF the wirelesss interface!
# There is also a bug where wireless network interfaces are caching DNS and causes problems when switching networks, so we need to clear them!
if ifconfig en0 | grep inet; then
/usr/sbin/networksetup -setdnsservers $airport "empty"
# Otherwise if Ethernet is not active we need to turn ON the wireless interface!
elif ifconfig en0 | grep inactive; then
/usr/sbin/networksetup -setairportpower en1 on
# Pause 10 seconds to allow for enough time for the network interface to intiate and get an ip address!
sleep 10
# Open AutoMount Script to mount network shares
su - "${consoleuser}" -c 'open /Applications/AutoMountScript.app'
# Prevent 169 IP Address problem for SSID RLCORP001
if [ $SSID = "RLCORP001" ]; then
if ifconfig en1 | grep 169;
then
# Prevent Access to RLINNO001
if [ $SSID = "RLINNO001" ]; then
# Prevent Access to RLSPOT001
if [ $SSID = "RLSPOT001" ]; then
# Prevent Access to RLAVID001
if [ $SSID = "RLAVID001" ]; then
# Prevent Access to RLSHEE001
if [ $SSID = "RLSHEE001" ]; then
# Prevent Access to RLGUES001
if [ $SSID = "RLGUES001" ]; then
# Prevent Access to RLBGAS001
if [ $SSID = "RLBGAS001" ]; then
# open networks control
# Prevent Access to BTFON
if [ $SSID = "BTFON" ]; then
# Prevent Access to BTFOpenzone
if [ $SSID = "BTFOpenzone" ]; then
Alrighty... I just think it's way longer than it needs to be...
Me too i tried shortening it with below but wifi kept turning off and on again constantly so i changed it back :(
Did you try Jared's case statement? My method was just a random shot and i honestly didn't know if it would work right. Apparently it doesn't Try out jared's script. I also think your script is too long for what my opinion is worth.
Not properly. I tried adding to the wifi variable the hardware port Airport to also cover 10.6 machines but got stuck on it and had to go cos it evening here :(
OK, if I'm not mistaken in 10.6 it returns as "AirPort" (note the capital "P") so make sure you grep or awk for that or you won't get proper results.
Anyway, give the case statement script Jared posted a try when you can. That should work.
Thanks guys will have a go in the morning. Sweet case statements... I've never done that before :)
morning guys
just stuck on one last command
I need to get the hardware port of Ethernet whether it is active or not. This to allow for different harware models etc
so some how to networksetup -listhardwareports but to only return the en0 etc of the Ethernet hardware port and another to get the wireless
As you can see below its nearly there but as you guys rightly said i cannot always be sure that ethernet is going to be en0 and wireless is en1.
I also tried setting a variable for the blocked ssids but i messed that up and stopped.
i changed some variable names for clarity
# HISTORY
# Version: 2.4
# - Created by Tim Kimpton on September 13th, 2012
# - Assisted by Jared Nichols and Mike from JAMFNATION to clean up and simplify the blocked ssid case statement and network interface variables
# Get the ethernet hardware port (ehwport)
ehwport=`networksetup -listallhardwareports | awk '/Hardware Port: Ethernet/' | awk 'NR==2' | cut -d " " -f 2`
# Get the wireless hardware port (whwport)
whwport=`networksetup -listallhardwareports | awk '/Hardware Port: Wi-Fi/,/AirPort/' | awk 'NR==2' | cut -d " " -f 2`
# Find the ALL network hardware ports (hwports)
hwports=`networksetup -listallhardwareports | awk '/Hardware Port: Wi-Fi/,/Ethernet/' | awk 'NR==2' | cut -d " " -f 2`
# Get the wireless network service (wservice)
wservice=`/usr/sbin/networksetup -listallnetworkservices | grep -E '(Wi-Fi|AirPort)'`
# Get the SSID
/usr/sbin/networksetup -setairportpower $whwport off
/usr/sbin/networksetup -setdnsservers $wservice "empty"
/usr/sbin/networksetup -setairportpower $whwport on
sleep 10
then
# Get the wireless network (wirelessnw)
wirelessnw=`networksetup -getairportnetwork $hwports | cut -d " " -f 4`
# Block the restricted wireless networks with a case statement below
case $wirelessnw in
esac
Give me a bit... I'll work this out.
Very interesting topic, Thank you.
Me too I would be interested in a "universal"- hardware-independent script (10.6+).
I would just use it to turn off Airport/WiFi when connected with Ethernet.
Ciao
Carlo
Okay so to detect your Wi-Fi interface, use this:
#Detect the wireless service name
wservice=`/usr/sbin/networksetup -listallnetworkservices | grep -Ei '(wi-fi|airport)'`
wifi=`networksetup -listallhardwareports | awk "/$wservice/,/Ethernet Address/" | awk 'NR==2' | cut -d " " -f 2`
To detect Ethernet use this:
ethernet=`networksetup -listallhardwareports | awk '/.Ethernet/,/Ethernet Address/' | awk 'NR==2' | cut -d " " -f 2`
This will first detect what your wireless interface is called (AirPort or Wi-Fi) - I changed your grep to include a -i to ignore case on your 'wi-fi' or 'airport' matching. I want to say that I recall that at one point it was 'AirPort' and then shortly before going to 'Wi-Fi' it was 'Airport.' At any rate, including the -i flag will catch all of the case permutations.
Warning
I haven't yet accounted for instances where you have more than one Ethernet interface (active or not). For instance, you're going to have issues if you've got a Mac Pro or a MacBook Air that's got two wired interfaces.
For instance, I've got mine plugged into a Thunderbolt display. The Display Ethernet is en3. If I plugged in a USB or Thunderbolt Ethernet adapter, I'd end up with another *Ethernet adapter - that "/.Ethernet/" bit in the awk command is a wildcard. The period before Ethernet matches anything before Ethernet. Thus it'll match Built-In Ethernet, Display Ethernet (from a Thunderbolt Display), Thunderbolt Ethernet and USB Ethernet.
If you want, you could take the result of having two *Ethernet interfaces and throw it through some logic to figure out which one is active. But, it looks like with your script, you're really more interested in nailing down which interface is the Wi-Fi. As I don't see your $ehwport called anywhere.
Mostly as an exercise to see if I could do it...I got rid of some of the pipes from the wifi command substitution. Also, used $() notation just because it is easy to confuse backticks and single quotes.
wifi=$(networksetup -listallhardwareports | awk "/$wservice/,/Ethernet/"' getline { print $2 }')
Apologies I'm not at work because its evening and I can't test anything.
I forgot I had $ehwport not being used. Forgive me but this still looks like it doesn't provide the ethernet en and wireless en.
I'm tryin to account for an eithernet en? plugged in and don't care which one it is. If ethernet isn't on i want wireless en? on.
Hope that makes sense. It still unfortunately looks like it will return service names.
Thanks guys I will have a look in the morning and things will hopefully be clearer :)
for checking for active ethernet you can do this, should be a little better than grep'ing the output of ifconfig...
[[ ipconfig getifaddr en0 ]] && some commands
OR
if ipconfig getifaddr en0; then
some commands
some other commands
I will work on the whole script after/during lunch if I can.
NOTE: for grep the way you are using it, when you NEED to, you usually want "grep -q" Then you are just checking for success or failure without any output etc.
I remembered while driving over to a different building that the last time someone wanted to do some fancy stuff that required accounting for Mac Pros, MacBooks Air, etc. etc. was when I decided I should learn Python.
Parsing all this via shell script sucks so bad... :(
It would be really nice if Apple followed the other nixes and BSDs and started using wlan0, eth0, etc for interface names. Or at least something different like ura0 for a ralink chipset or whatever.
@tkimpton going back to your original question about blocking certain SSIDs why don't you just
- clear out the preferred network list
- add the network you want to the list
- require admin password to change
- then join the specific network.
Is this not an option?
Unfortunatly not we use certificates and for us in it we need access to those other ssids for other reasons unknown to the normal user.
Thanks for the grep -q advise. I don't intend to ever get say macbookairs in her but hey never know what management will just go. And buy then throw it on my desk to set up, just like the ceo did yesterday!
Hmmmm there just no gurantee that ethernet is en0 etc.
Possibly only other was is system profiler info our outputting the en? For Ethernet to a hidden file at startup and referencing that.
Not sure if it possible but for it to work properly for all models then some sort of referincing needs to take place.
Night guys I'm resting my brain for a bit.
I was thinking this might be cleaner in straight up awk...
turns out not so much. at least with my proficiency :D
But at more than 5 or so lines this is the biggest thing I have EVER tried to do in awk and I learned a LOT!, so not all bad.
I give you tkimpton.awk ;) All it really does is turn off Wi-Fi if an IP address is found on an Ethernet interface. Assuming of course there are no custom service names.
run like so:
networksetup -listnetworkservicesorder | ./tkimpton.awk
EDIT: see commented & updated code below
