Hello All,
We are about to roll out SEP (symantec enterprise protection) to both our Win and Mac machines on campus. Based on some of the other posts I have SEP packaged and included the "sylink.xml" file based on if they are labs or workstations to auto join our SEP 12 management server. I have some questions though on what others are doing for updates and scanning as well as my package.
I only added the sylink.xml file from the Additional Resources folder. Are the other files needed? I couldn't find anything about where they should go or what if anything was needed. They include sep.slf, setAid.ini, setup.ini and the dat file which I think the system can just download.
What does everyone do for liveupdates? Do you liveupdate all products, just virus definitions and then push product updates via casper?
I am also looking at a scan schedule. I am thinking about making all labs scan daily, and then have office scan weekly. Anyone else in education have any suggestions?
Thanks for any feedback.
Joe
