We have installed basICColor color management software on all our Macs, and now there is a specific configuration file (.dcj) that we need to place into a User Settings folder. The folder path is ~/Documents/basICColor display 5/UserSettings . What I want is to make a package that simply drops that file into that folder for all user folders on a given Mac.
I tried making the package in Composer by dragging the configuration file into the left sidebar under Sources, and building the package. I then placed the Package in Casper Admin, and made sure to turn on Fill Existing User directories. I then tested installing the pakage with Remote on my Mac and my coworkers Mac. It worked on mine but not his.
What am I doing wrong here? I'm thinking that its something to do with how I am building the package, in that it worked for me since it knew the exact path to install to as it was built on my machine. Is there a simpler way to tell Casper "Take this file and put it here for everyone"?
Thanks,
-Mike
