Recently we've had issues with people on Yosemite running into slowness and crashing issues. Were working with Apple on this and it seems to be a known issue. Apple says it's related to Active Directory and FileVault. So we're looking at disabling FileVault and Active Directory to try to help our users until Apple can find a fix.
So in trying to decrypt FileVault from yosemite machines we run into an interesting issue. When a user tries to log in with their Active Directory credentials they get an error message saying: "Your administrator requires that you enable FileVault. You must enable FileVault now to continue." The only option they have is to re-encrypt, but that doesn't help us here. Were currently using Individual FileVault method. The only FileVault user is the user themselves.
Doing further testing I found that this only occurs on Yosemite machines. When I try to decrypt a 10.8 or 10.9 machine I can log in fine with my Active Directory record.
Have you guys seen this error? Are you guys able to decrypt the machine?
