On the JDS CentOS 7 box I am developing I started a:
nohup jamfds inventory &
I think this will inventory all the dmg and other packages that I secure copied across from the Mac Mini Casper JSS to the new JDS CentOS 7 box.
After running the command I exited (nohup so the inventory will keep running even after an exit) and now when I try and ssh in I get a port 22 connection refused.
Does anyone know how long jamfds takes for say 23 packages mostly dmg ones? Why is it refusing an ssh connection?
Thank you
Be the first to reply!
