Automatic Scoping of Devices for DEP
  • April 15, 2015
  • 9 replies
  • 31 views
I've got my DEP working a treat with Casper but I can't see how I get the scope of the prestage enrollment to automatically include any new devices. At the moment I am having to go into the scope and edit it to tick the new devices. Sure I am missing something simple!
Thanks
Best answer by fbaker
@etippett Right next to where it says "Device" on the left hand side. When I click edit for my prestage enrollment. I'm still setting my environment up, but I would think you would have this option as well. Currently mines unchecked as I've just been doing some testing.
If you have a checkbox next to the red arrow pointing at it, that should solve your issue.
  • April 15, 2015
Have you tried checking the checkbox that says "device" so any new devices that are for prestage enrollments are automatically selected?
  • April 15, 2015
@fbaker Can you elaborate on the "device" checkbox or provide a screenshot? Is that located in the PreStage enrollment? I'm on Capser 9.63 and see no such thing
  • April 15, 2015
  • April 15, 2015
@fbaker AH HA! Thank you. Didn't realize it only showed up in Edit mode.
  • April 15, 2015
@etippett Glad you got it working!
  • April 16, 2015
Thank you, didn't realise that tick box would also select future devices!
Forum|alt.badge.img+15
  • April 16, 2015
While this button does let you select all, in my environment at least, it doesn't add future devices.
  • Employee
  • August 24, 2015
Hello everyone, as @cbrewer referenced this will not check future devices automatically.
That said please check see this feature request for more information on this functionality which we plan on releasing with version 9.8: https://jamfnation.jamfsoftware.com/featureRequest.html?id=3550
Thanks for posting!
  • August 24, 2015
Great to know. Thanks Eric!
