Ok I know that i cannot prevent a user from installing a specific app unless i deny installing of apps. Is there a way in casper to deny an app to launch that is already installed? Any info would be helpful Thanks
I am also very interested in the solution to the question asked above. I originally thought that there was a way to block specific Apps from being installed.
I am in higher education and We have unsupervised iPads, but they are managed by us. The faculty have requested multiple times to block particular apps, even if only during certain times. They are using Focus to take over the class, but I think that prevents them from collaborating and offering more to the discussion. How would you add an app and then not allow it to be installed?
