In the JSS go to Settings tab --> LDAP Server Connections and test whether you receive results. I would imagine that during this down time it will fail but it's the first thing I'd do for testing.
Does your JSS use an authenticated AD account to connect to AD? Do your AD logs show any errors for that account? For testing purposes, change the account to a different known working account (such as your own) to see if that works better.
My gut tells me this is probably a network or DNS issue. We pointed our JSS to a single DNS address that was set up round-robbin for our Global Catalog servers. Later, our Network Services folks bypassed changed management and decided to point the DNS entry to a load balancer, which broke stuff until we figured out what they did.
We have a similar problem every now and then,
when the AD service-account used for LDAP lookups and AD bindings gets locked out by the DC.
Couldn't find a reason for that yet, the account is used only by the JSS.
Weird...
Thanks for the suggestions. We tried most of this already (not the first time with Macs and AD issues) and I remember a "trick" we had to do when we had Exchange running and the Mac Entourage clients. We needed to edit the settings to point to only one domain controller.
So rather than just point to our AD domain (ad.organization.edu), we are
now pointing our authentication at a specific domain controller
(control2.ad.organization.edu). This has kept us stable since last
week. One note of caution, if that controller goes down. someone with
a local account will have to login and change the controller the JSS
is pointing to.
I hope this will save someone sometime in the future.
-Barry
$0.02 We have been doing AD auth to Casper since v7 and have NOT experienced this issue.
The only difference I can see from the provided info. is that our server IS bound to AD. Although how that would make a bit of difference in the JSS LDAP lookups is not clear.
We have the issue about once every two weeks. when it happens, I go into the jss, go to the network pref in system prefs and go to advance and then dns. i change something then change it back and save. this always clears the issue. So it has to be some sort of DNS hiccup for us.
