iOS 6 Enrolment into casper - SCEP ERROR!
  • September 27, 2012
  • 17 views
Hi All,
Just wondering is anyone else experiencing the following error Profile Installation Failed.
The Server Certificate for "https://blah.blah.blah:8443/Blah/enroll/SCEPProfile?invitation=Blahblahblah" is invalid. installing the MDM Profile...
This works on ios 5 clients not on ios 6?? both Versions of JSS 8.52 and 8.61 ????
Any Ideas???
Best answer by ibayssari
Brett Jacobs from compnow is a legend.
Fix
Replace keystore.jks
and replace server.xml
When doing an upgrade from 8.5 to 8.6 this replaces current "Server.xml" and Keystore.jks file.
Please ensure your server has been backed up prior to doing any upgrade.
Regards
Isaac
1 reply
Fix
Regards
Isaac
