How to check if a computer is ACTUALLY bound to the AD
  • April 9, 2013
  • 20 replies
  • 225 views
So right now, I use dsconfigad to tell if a computer is bound to our AD, and while that works beautifully, it is not complete. For example, I can have ```
dsconfigad -show
tell me I am bound, but if the computer account has been deleted in AD, from the AD-side of things, -show will still tell me I am bound, though I will not be able to
id $adUserName
Does anybody have a better scripting process or workflow that gives me a truer idea of whether or not I am bound and fully functioning from a directory services standpoint to our AD?
  • April 9, 2013
It sounds like you already have the solution with the items in your post. Do a check first with dsconfigad -show to determine if the domain is correct, then do a id -u $someaduser and if that fails, the Mac is not properly bound. You'd have to be sure you're checking an account that never gets deleted though.
This of course all assumes you are in scope of your DC or the id command will fail anyway, so you might want to first do a quick ping check against your AD before continuing.
Something along these lines should work, although it would need to be tested for failure cases.
ping -c 3 -o adserver.org.your.domain 1> /dev/null 2> /dev/null
# If the ping was successful, we're in range of the DC
if [[ $? == 0 ]]; then
    # Check the domain returned with dsconfigad
    domain=$( dsconfigad -show | awk '/Active Directory Domain/{print $NF}' )
    # If the domain is correct
    if [[ "$domain" == "org.your.domain" ]]; then
        # Check the id of a user
        id -u adusername
        # If the check was successful...
            echo "The Mac is bound to AD"
            # If the check failed
            echo "The Mac is not bound to AD"
        # If the domain returned did not match our expectations
        echo "The Mac is not bound to domain"
    # We can't see the DCs, so no way to properly check
    echo "Not in range of DC"
  • Employee
  • April 9, 2013
I was just putting an Extension Attribute together as well. My only concern in my was what "id" I use. Obviously you want to use an "id" that you know isn't going to quite, get laid off, or deleted due to inactivity.
# Check to see if it is bound by running the "id" command.
AD=`id XXX`
# Tell us if it's Bound or not.
if [[ "$AD" = "no such user" ]];
then
      echo "Not Bound"
      echo "Bound"
I'm open to any suggestions as well.
Forum|alt.badge.img+15
  • April 9, 2013
You could search AD for the computer's own computer record. If it can't be found you know either the computer record doesn't exist or the computer isn't talking to AD.
Something along these lines...
ad_computer_name=`dsconfigad -show | grep "Computer Account" | awk '{print $4}'`
dscl /Search read /Computers/$ad_computer_name
  • April 9, 2013
cbrewer's suggestion is good. Using the same logic as above, check to make sure you can talk to AD first, then if the Mac is claiming its bound to AD with dsconfigad -show and finally, if it can find its own record. That makes more sense that checking a user.
@krichterjr - I would use an account that you use for things like binding purposes, if you have something that is designed for that only and no-one logs into. I assume such an account probably wouldn't get deleted from AD, or you'd have other issues to worry about. :)
  • Employee
  • April 9, 2013
@cbrewer - That does make more sense to have the computer check for it's own record than a user. Thanks
  • April 9, 2013
Yea, the problem is that the Macintosh will think it's bound to Active Directory, even if the Computer account is no longer accessible. There's discussion over in this thread: https://jamfnation.jamfsoftware.com/discussion.html?id=7004.
Over there, I posted my Extension Attribute that has worked well for us (and identified other Computer accounts that have failed, requiring us to rebind to AD):
domain="YOURDOMAIN"
user="someuser"
# Can we query a UPN?
domainAns=`dscl /Active Directory/${domain}/All Domains -read /Users/${user} dsAttrTypeNative:userPrincipalName`
if [[ $domainAns =~ "is not valid" ]]; then
    result="Invalid"
        result="Valid"
  • April 10, 2013
https://github.com/jatoben/dsstatus
Nice like command app here that checks the directory status, combine this with a launchDaemon or agent or JSS policy to check is a client can access the AD / OD etc, you could then script it to restart the opendirectoryd or rebind via script if needed
  • April 10, 2013
@mm2270 just two quick tips :)
In this bit here:
You can do the following to make things a bit cleaner.
  1. if you want to redirect both stdout and stderr to the same place you can use the '&>' operator. Like so:
ping -c 1 www.intel.com &> /dev/null
  1. You can also use the command directly on the if statement line. You don't need to seperate them out and check the exit status.
if ping -c 1 www.intel.com &> /dev/null; then
    echo 'yes'
    echo 'no'
or
if grep -q "${input}" "${file}"; then
etc. etc.
Cheers,
Ryan
  • April 10, 2013
dsstatus is essentially performing the same lookup as the ```
``` command from above and dscl is already built into all of your systems, no need to compile a binary and distribute.
  • April 10, 2013
@rmanly,
Yeah, I do know of the &> /dev/null approach, and usually use that. The above was pulled from a different project I was working on that actually required the separate stdout and stderr redirections. Too much to explain right now, but the usual approach wasn't giving me the results I wanted, so I had to do it that way. But you're right, under normal circumstances, that does work fine.
  • April 11, 2013
re - pickerin,
That line only covers AD Binds only, however DSStatus binary can cover ALL directory bindings,
Plus not everyone wants to write long lines of code and troubleshoot them,
All i do is install dsstatus on my macs (part of the complied image), then create an extension attribute as follows
+**#!/bin/sh
/usr/sbin/dsstatus
if [ $? -eq 0 ]
then
echo "<result>Pass</result>"
echo "<result>Fail</result>"
fi**+
Thats its, jobs a gooden, much shorted code, much easier and quicker, and times money. I could then scope it to a smart group for "is" "Fail" and then bind or rebind etc.
If i need to check a mac i can do this in Casper Remote, with a single line
dsstatus -v
and get full read out of ALL directory statuses
So much easier for me and covers my Ad and my OD status
  • April 11, 2013
@Bukira "write long lines of code and troubleshoot them", as opposed to downloading source, firing up XCode, and compiling the binary for 32-bit and 64-bit machines. Makes sense.
Yes, the dscl line is only for AD binds, of course that's what the OP asked for.
  • December 20, 2013
use ldapsearch to do a dynamic lookup of the AD and grep for the computer account. Use a service account that has no password expiration. The beauty of ldapsearch is that you can bind to the domain on the fly to do the lookup, so it will work even from unbound Macs.
ComputerName=`scutil --get ComputerName`
LDAPName="your.AD.service.account"
LDAPPasswd="service.account.password"
LDAPAD="domain.example.com"
SearchBase="DC=domain,DC=example,DC=com"
MacOU="ou=Macintosh,cn=Computers,dc=domain,dc=example,dc=com"
IsInAD=$(ldapsearch -LLL -h "$LDAPAD" -x -D "$LDAPName"@"$LDAPAD" -w "$LDAPPasswd" -b "$SearchBase" "name=$ComputerName" | grep name)
  • December 22, 2013
@acdesigntech,
Is there a way to do the same but avoid caching the password and NOT prompting for one either? I just hate the idea of password in the clear.
  • December 23, 2013
I would think you could store a hash of the password for the AD user in a text file in a secure location, and have the script read the hash and convert it on the fly.
use ldapsearch to do a dynamic lookup of the AD and grep for the computer account. Use a service account that has no password expiration. The beauty of ldapsearch is that you can bind to the domain on the fly to do the lookup, so it will work even from unbound Macs. #!/bin/sh ComputerName=scutil --get ComputerName LDAPName="your.AD.service.account" LDAPPasswd="service.account.password" LDAPAD="domain.example.com" SearchBase="DC=domain,DC=example,DC=com" MacOU="ou=Macintosh,cn=Computers,dc=domain,dc=example,dc=com" IsInAD=$(ldapsearch -LLL -h "$LDAPAD" -x -D "$LDAPName"@"$LDAPAD" -w "$LDAPPasswd" -b "$SearchBase" "name=$ComputerName" | grep name)
Could I throw this into an Extension Attribute pulling the data as a string? This is something I would like to be updated on my machines to ensure ones that are on the domain get specific actions.
  • July 7, 2014
you can, but the output of that command is either nothing or the computer name. If you wanted to put some more appropriate info, you can always do something like ```
if [ $? == 0 ]; then echo "<result>your.domain.name</result>"
else echo "<result>Not Bound</result>"
or similar when defining the EA
  • July 7, 2014
bound and actually functional are two different things, computers can report bound in @acdesigntech solution, but still not be able to authenticate via AD, if a computer is moved to an OU that is for "inactive" computers. most generally the best solution i have seen is to check for an account that should not be on the computer in a local mobile account, such as using my bind account and an id command.
if the id bindaccount command returns unknown user, then its likely lost its trust relationship in windows terms, or needs rebound regardless of what dsconfigad says the bound state is.
Thanks acdesigntech for the input your addition to your original code works for my process.
I know this is super old, but I've combined the information you guys have given into a complete bash function. I've tested it a bit to make sure it's working, but haven't tested it thoroughly. Forgive the highlighting; the Insert Code function here doesn't have a bash setting, so I chose PHP.
# Checks if the computer is bound or not to Active Directory. checkForAD(){ strADDomain=$1 # Returns: # "bound" # This mac thinks it's bound and the domain thinks so too. # "unbound" # This mac thinks it's bound, but the domain doesn't think so. # "incorrect domain" # If the domain returned from the computer did not match what we thought. # "not in range" # We can't see the DCs, so no way to properly check # Reference: # https://community.jamf.com/t5/jamf-pro/how-to-check-if-a-computer-is-actually-bound-to-the-ad/m-p/55809 if [[ $strADDomain == '' ]]; then echo "Domain Not Given" return 1 fi # Ping the domain we're expecting ping -c 3 -o $strADDomain 1> /dev/null 2> /dev/null # If the ping was successful, we're at least within range of the DC if [[ $? == 0 ]]; then # Check the domain returned with dsconfigad. This tells us what the computer thinks it's # connected to. domain=`dsconfigad -show | awk '/Active Directory Domain/{print $NF}'` # check if something returned if [ ! -z "${domain}" ]; then # If the computer's reported domain is the same as what we expect... if [[ "$domain" == $strADDomain ]]; then # Get the computer name from the computer... ad_computer_name=`dsconfigad -show | grep "Computer Account" | awk '{print $4}'` # ...and check if it's in AD dscl /Search read /Computers/$ad_computer_name 1> /dev/null 2> /dev/null # If the check was successful... if [[ $? == 0 ]]; then # This mac thinks it's bound and the domain thinks so too. echo "bound" return 0 else # This mac thinks it's bound, but the domain doesn't think so. echo "unbound" return 0 fi else # If the domain returned from the computer did not match what we thought. # This might happen if the computer is bound to a different AD. echo "incorrect domain" return 0 fi else # This computer doesn't think it's bound to anything. echo "unbound" return 0 fi else # We can't see the DCs, so no way to properly check echo "not in range" return 0 fi }
