All:
Suddenly as of this morning I am unable to use the QuickAdd pkg to add machines to the JSS. I get the following in the install log:
Feb 15 11:45:24 a201526 runner[3587]: postflight[3595]: Finding Extension Attributes...
Feb 15 11:45:24 a201526 runner[3587]: postflight[3595]: Submitting data to https://pegasus.butler.edu:8443//...
Feb 15 11:45:25 a201526 runner[3587]: postflight[3595]: There was an error submitting the computer to the JSS. The JSS responded with a status of 401.
Feb 15 11:45:25 a201526 Installer[3572]: Install failed: The following installation step failed: run postflight script for QuickAdd. Contact the software manufacturer for assistance.
I get the same thing when I run a 'jamf recon' from the command line. I tried restarting tomcat on the JSS, but the issue was not resolved.
Any ideas?? Help!
-Andy
