We are setting up images and netbooting across our network. We have the image part down no problem.
We are wanting to split up the HD into a OS partition and a data partition.
For some reason the script we are using errors out during the imaging process, however, when we run it thru target mode to a machine it works perfectly. We are imaging eMacs to 10.4.11.
The error from the jss log is as follows:
Result of running split_part.sh was: Partitioning encountered error Could not unmount disk (-10000) on disk disk0
The scripts is as follows:
#create two partitions, one data and one for the OS
/usr/sbin/diskutil partitionDisk disk0 2 HFS+ 'Macintosh HD' 50G HFS+ data 23G
echo 'done'
any ideas?
Thanks in advanced....
Mark Hughes, Apple Technician
TIS Department, KCKPS USD500
Cell 913-449-7791
mahughe at kckps.org
