Anyone else using Symantec PGP for encryption?
  • December 18, 2014
  • 20 views
We're having problems deploying their latest clients using with Casper, wondering if anyone else is seeing the same thing? thanks!
  • February 23, 2016
Hi @mapurcel - how did you get on? We're just looking at this and get the following error with the default package:
"An error occurred while extracting files from the package “PGP Desktop.pkg”."code object is not signed at all"
  • February 23, 2016
@jazzyj I found that if you rename the package it revokes the signature so leaving the default name of the installer worked for me
