[Off Topic] ARD on 10.7.3
  • February 21, 2012
  • 14 views
ImAMacGuy
Forum|alt.badge.img+23
So, you ever do something stupid? I do something stupid fairly often.
I was trying to enable root so I can modify some plists I couldn't access as admin on my backup server. I was able to ssh in, and add the root account to the ard kickstart thing and restart the service, but now whenever I try to connect to the machine ARD says Connection Failed. I checked the username and password, i tried the root and the admin. I ssh'd back in and rebooted the server, but I still can't get a desktop.
Any suggestions on how to un-snafu this?
Best answer by genes
Whenever I have problems with ARD, I fall back on this kb:
http://support.apple.com/kb/HT2370
Hope it helps.
  • February 21, 2012
Hope it helps.
ImAMacGuy
  • February 21, 2012
sudo /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -activate -configure -access -on -restart -agent -privs -all
thank you! This is why you make the big $$$
