Hi-
So we've got two DPs thus far. Folks in one location use one DP, folks in another location use the other. Pretty simple.
We're looking to add a JSS in the DMZ to handle management of machines off the internal network and also set us up for potential iOS management.
Here's the question: In the KB for installing a JSS Web Application in the DMZ, it indicates that you should setup an all-encompassing network segment (0-255) and set the DP in the DMZ as the default DP.
Does this essentially undo the "regional-ness" of having multiple DPs? How do we then handle the spread-out nature of our workforce if people are hitting only one external JSS? Input from those with global deployments desired.
Thanks
EDIT: To clarify, ideally we'd like to deploy policies externally as indicated in the KB article.
