Ftp site for flash player?
  • December 20, 2014
  • 7 replies
  • 66 views
Forum|alt.badge.img+20
Dose annone know were the ftp site is for getting the flash player .pkg? So i can use it to setup a policy to install it. Thanks
Best answer by mm2270
Sign up for a distribution license at the link below. Its free and doesn't take long to do. They'll send you an email with a link you can use to download the regular OS X installer package, rather than the one you get by going to http://get.adobe.com/flashplayer/
http://www.adobe.com/products/players/flash-player-distribution.html
  • December 20, 2014
  • December 21, 2014
mm2270 - yes thanks, the http://get.adobe.com/flashplayer/ downloads a .dmg then when I run it, it goes to a download to do the install.
i'll sign up for distribution license. Will the link that is given to me contain the OS X installer package each time a new version of flash-player is released?
I'll be able to use this .pkg to create a policy to install flash-player? no need to do any sort of scripting or anything like that?
thanks
  • December 21, 2014
Yes, the link you'll get can be used each time a new release comes out and will download a standalone installer that doesn't need to go grab some other pieces like the DMG you get at get.adobe.com/flashplayer.
You may want to also look into getting and setting up AutoPkg on a system, like an internal Mac server, and have it auto download the latest releases for you on a schedule. It uses the same links to get the latest version. For Flash Player and lots of other products.
  • December 22, 2014
We use a script called fetchFlash and pass to it via the casper $4 place holder the flash version (latest) that should be installed. It checks the installed version and if not a match curls the latest dmg down from: "http://fpdownload.macromedia.com/get/flashplayer/current/licensing/mac" mounts it and installs it. Found this overall easier than installing a package each time, just have the client grab it.
davidacland
  • December 22, 2014
jescala
  • December 22, 2014
@tcandela After you sign up for Flash Player distribution with Adobe, I suggest you check out @rtrouton's Flash Update script...
https://github.com/rtrouton/rtrouton_scripts/tree/master/rtrouton_scripts/install_latest_adobe_flash_player
  • December 23, 2014
I typically get the flash player (DMG installer for system administrators) here:
http://www.adobe.com/products/flashplayer/distribution3.html
