I believe it is just ipfw
larkin$ ipfw -h
ipfw syntax summary (but please do read the ipfw(8) manpage):
ipfw [-acdeftTnNpqS] <command> where <command> is one of:
add [num] [set N] [prob x] RULE-BODY
{pipe|queue} N config PIPE-BODY
[pipe|queue] {zero|delete|show} [N{,N}]
set [disable N... enable N...] | move [rule] X to Y | swap X Y | show
RULE-BODY:check-state [LOG] | ACTION [LOG] ADDR [OPTION_LIST]
ACTION:check-state | allow | count | deny | reject | skipto N |
{divert|tee} PORT | forward ADDR | pipe N | queue N
ADDR:[ MAC dst src ether_type ]
[ from IPADDR [ PORT ] to IPADDR [ PORTLIST ] ]
IPADDR:[not] { any | me | ip/bits{x,y,z} | IPLIST }
IPLIST:{ ip | ip/bits | ip:mask }[,IPLIST]
OPTION_LIST:OPTION [OPTION_LIST]
OPTION:bridged | {dst-ip|src-ip} ADDR | {dst-port|src-port} LIST |
estab | frag | {gid|uid} N | icmptypes LIST | in | out | ipid LIST |
iplen LIST | ipoptions SPEC | ipprecedence | ipsec | iptos SPEC |
ipttl LIST | ipversion VER | keep-state | layer2 | limit ... |
mac ... | mac-type LIST | proto LIST | {recv|xmit|via} {IF|IPADDR} |
setup | {tcpack|tcpseq|tcpwin} NN | tcpflags SPEC | tcpoptions SPEC |
verrevpath
I think it's ipfw
Eric Winkelhake
MundocomWW
312.220.1669
312.504.5155
eric.winkelhake at mundocomww.com
