Dock Items policy on new accounts
  • April 22, 2015
  • 13 replies
  • 80 views
I have a Policy with the Dock Items payload. It's just set to remove a few of the defaults like Calendar and Mail since we use Outlook instead. We're seeing some strangeness when following this procedure:
1) Network booting and using Casper Imaging to re-image a new mac (used AutoDMG to start with a clean image). A local admin account is created with a package.
2) After the imaging process is complete, i can log into the local admin account that was created and the dock looks just fine.
3) If i create a new standard user, or if an AD user logs in for the first time, then the dock may only have 1-3 icons on it. Usually Finder, Maps, and iBooks.
That's strange because I'm not removing System Preferences, Launchpad, Safari, or many others with my Dock Icons payload. I'm also not touching "/System/Library/CoreServices/Dock.app/Contents/Resources/en.lproj/default.plist". "/Library/Preferences/com.apple.dock.plist" doesn't exist and neither does "/System/Library/User Template/English.lproj/Library/Preferences/com.apple.dock.plist" which I'm not doing anything with either.
But, if i disable the Dock Items policy then everything works fine. Has anyone seen something like this?
I'm also thinking of ways to work around this if it is a bug. Does anyone know if Mavericks/Yosemite prefer either the default.plist in the dock.app or the com.apple.dock.plist in the User Template? Would it merge those settings if they're different?
Forum|alt.badge.img+15
  • April 22, 2015
could be byHost prefs. Is your imaging workflow running fix byhost prefs?
  • April 22, 2015
I use a com.apple.dock.plist file that I insert into the User Template folder. It works well to put all our default apps on the Dock. We have a couple of different default Docks depending on the target computer's department. For example, some computers get Adobe Creative Cloud apps, and others don't.
However, there is still some minor "cleanup" to do after you log in a user because it still loads "iBooks," "Maps," and "Notes." It also duplicates the "Downloads" folder. I've been trying to figure out a more definite way to really force only our Docks to load. No extra cruft.
I used to be able to set plists via Workgroup Manager, and an extended AD schema to target user groups. That method has been abandoned by Apple, and Configuration Profiles are much too strict. I only need a starter Dock and other prefs that the user can then customize. Config Profiles only offer always or never proposition, and I'd have a riot in my hands if people couldn't change their Docks.
  • April 22, 2015
@RogerUL I don't think i am. I just double checked and am not seeing any policy running that does the "Fix ByHost Files" maintenance task, and I haven't scripted something similar.
@itupshot Perhaps the default.plist file in dock.app is loading iBooks, Maps, Notes; and then com.apple.dock.plist is merging in your items. I've noticed a duplicate Downloads folder as well when i started playing around with them.
RobertHammen
Forum|alt.badge.img+29
  • April 22, 2015
/System/Library/CoreServices/Dock.app/Contents/Resources/com.apple.dockfixup.plist is your enemy.
  • April 23, 2015
@RobertHammen Thanks for that tip. Looking in that file i do see the add-app section that specifically adds Maps and iBooks. So is com.apple.dockfixup.plist the end all be all when it comes to setting up the Dock? I'm unsure why there are 3 files related to setting up the dock:
When a new user account is created, how do these 3 interact? The Dock Items payload must be doing something that tells dockfixup to apply (3+2 items), since not running that payload causes the standard full dock (16+2 items) to apply
  • April 23, 2015
@RobertHammen
Would deleting <insert file> during a first run script set to 'Reboot', after imaging solve the issue of these apps appearing?
rm /System/Library/CoreServices/Dock.app/Contents/Resources/com.apple.dockfixup.plist
RobertHammen
  • April 23, 2015
Yes, however be aware that after some system updates (i.e. 10.10.2->10.10.3) Dock.app may be replaced and the dockfixup.plist added back, so keep that in mind.
  • April 23, 2015
This one-liner will get rid of the additional apps added with dockfixup.plist
/usr/libexec/plistbuddy -c "delete:add-app" /Library/Preferences/com.apple.dockfixup.plist
RobertHammen
  • April 23, 2015
I tried that with 10.10.2 and for whatever reason it didn't work. Only way I could was to delete the com.apple.dockfixup.plist itself, which obviously isn't desirable. Have not tested with 10.10.3 yet...
  • April 29, 2015
+1
I'm struggling with this as well.
  • April 29, 2015
Looks like that plist got moved in 10.10. Try this:
sudo /usr/libexec/plistbuddy -c "delete:add-app" /System/Library/CoreServices/Dock.app/Contents/Resources/com.apple.dockfixup.plist
RobertHammen
  • April 29, 2015
This might be another tool to try... it's a web-based configuration profile generator, but pretty slick:
http://errorfreeit.com.au/blog/2015/4/28/dock-master4
  • September 24, 2015
So when is this called? We still need to remove Photos, Maps and iBooks.
