OT - Loaner Laptops
  • December 29, 2014
  • 38 replies
  • 174 views
emily
This is more a conceptual question than anything else…
I'd like to have loaner laptops set up that are ready for employees to use if they leave theirs at home or have hardware downtime. I was curious to see what other folks here might have set up for that. My initial hesitancy with just imaging out a machine is handling permissions… do I just create a local account that folks use on that machine, and then wipe it every other week? Have users log in but not have admin rights?
(FWIW, our environment is all laptop users are admins on their laptops, hence the concern with permissions.)
Any ideas or feedback welcome. And sorry for something kind of off-topic. Thanks!
Best answer by acodega
My environment is identical to yours.
Most people here do all their work on the Web so all they need is Chrome to get through the day.
I create an admin account on the loaner laptop for them in their name, when they return the laptop I login with the other admin account and delete the account that was created for them. I don't see any risks doing it this way.
If it's unique and they needed Adobe suite or etc installed on the laptop then I'll image it when it comes back to me. Thunderbolt TDM image takes about 6 minutes.
acodega
Forum|alt.badge.img+15
  • December 29, 2014
emily
  • December 29, 2014
So you create a local user profile that is an admin? Or you make them log in with a network account?
acodega
  • December 29, 2014
Local admins, yes. That's what the have on their assigned laptop too. Was the challenge for you adding a network account as local admin?
ImAMacGuy
Forum|alt.badge.img+23
  • December 29, 2014
we have a small handful of laptops we use for loaners (first come first serve), they are imaged every time we give them out, sign in with their domain credentials, and load any extra software is needed for the duration of their down time. machine gets returned to us and then imaged again and then ready for the next user.
Our bigger problem is ensuring we get the loaner back :)
emily
  • December 29, 2014
@adamcodega yes, trying to weigh making local admins each time versus using network accounts. A lot of what folks need in general in our org is web-based, so I'm guessing it doesn't really matter… just trying to figure out the easiest way to have something ready that doesn't involve wiping and reimaging every time someone needs it.
@jwojda right?! I'm guessing that would be our issue too. Getting them back. How much time does it take you to get a machine ready for the user? Do you just have a standard image and then manually install what's needed?
  • December 29, 2014
We manage a decent number of Mac loaner laptops in our environment.
We add the customer's network account as an admin and when they return the laptop, we do a secure delete of their account/home directory. If they install a bunch of cumbersome apps (Adobe products, I am looking at you), then we just do a full re-image.
We keep about 5 of them hot on the network at any given point to ensure they are fully up to date so all we have to do is add their account and have them login with their network account, enable FV2 and then they are done.
acodega
  • December 29, 2014
Agree with @JRossA, leverage secure user delete.
So for the sake of overthinking.. if they need to sign in with their network account to get where they need to go, then use or have them use Self Service to get the apps they need.
Depending on how much you need to loan out systems I'd setup (another) space machine to run Casper Imaging and image them via Thunderbolt Target Disk Mode. Like I said an AutoDMG image takes about six minutes.
Forum|alt.badge.img+33
  • December 29, 2014
We have a stock of loaners that are both bound to AD and also set up with a local account named loaner. That allows us flexibility because we can either have our folks log in with their AD account or have a visitor log in with the loaner account. The loaner account has admin rights, and we grant admin rights to our folks' AD accounts.
We have a DeployStudio workflow that sets up our loaner laptops with a standard configuration, including the loaner account (the account is created by a CreateUserPkg-built installer package.) When a loaner laptop comes back in, the person who manages our loaner stocks boots to DeployStudio and runs the workflow to completely wipe the laptop and reload a fresh copy of the loaner laptop configuration. Total time to reimage is about 45 minutes, with the person running the process needing to devote about 5 - 7 minutes to run the workflow.
Getting the loaner laptops back in a timely manner is definitely the most challenging part. We partially compensate for that by having a relatively large stock of loaners.
  • December 29, 2014
We have a 3 week loaner checkout limit and then we start squawking at them to return them.
if they don't return it, we charge their department the cost of the laptop. =D
  • December 29, 2014
FWIW, we use Deep Freeze on our loaners and it's worked well. We don't ever have to image more than once and people are usually good about not keeping them too long, as the longer they have them, the more likely they run the risk of losing data.
emily
  • December 29, 2014
I've got some good ideas now, thanks y'all!
Chris_Hafner
Forum|alt.badge.img+27
  • December 29, 2014
Alright... I have to jump in as well as most of our users are rather file dependent.
We maintain a statistically large fleet of loaner laptops. 30 for our ~650 users, which are always imaged and on shelf to cover our two main user populations (Students and Faculty/Staff/Admin). At present we would either create an admin account for our non-student population or use a generated "student" account (local) for our students. We transfer 90+% of their home directories from the computer to be repaired or from their backup drives. We are pretty picky about permissions and the user library so we don't transfer anything that doesn't directly affect their own configurations or settings.
Upon completion of their repair we give our users a few days grace when their computer is repaired to come pick it up before I set a few semi-annoying policies on them. The policies just pop up a nice reminder, once a day, to bring their loaner back as their computer is ready. We've had almost perfect success without having to get more persistent.
Beyond that, we're slowly moving to an integration with Code42 and CrashPlan (ProE or whatever it's called) to automate the file transfer without direct AD binding. I'll love posting that info up in the future when we have it all hashed out! We don't often have a lot of time to get our users back up and running so having this in the background without resorting to network accounts will be pure gold for us!
Forum|alt.badge.img+31
  • December 29, 2014
Hi Everyone,
This was my experience at my last job regarding loaner laptops. We initially had sets of laptops designated as loaners, and in the event of a hardware failure or significant downtime due to troubleshooting, we would swap out our users with a loaner laptop. In the event of hardware failure it was about a 1 week turn around time for repairs. We had to ship the laptop to our tech depot, they had to order the parts, replace the parts, and verify it was fixed. With everything involved from initial diagnosis, travel time, waiting for parts, etc. it was pretty typical for a laptop to take about a week to get back into working order.
What I learned from this experience is that users would get the loaner and create a week's worth of projects, data, and work on that laptop. They would also take the time to restore their personal data, like iTunes collection so they could listen to music while they worked. We would then contact the end user via email that their laptop was back and they could turn in the loaner. This process proved to be ineffective, as the user already had a new laptop, with data on it, and all back ups restored, plus a week if not more worth of work on it.
We had 6,000 Mac laptops at my last gig. We purchased them all at the same time on a set life cycle, meaning all of our loaners were the same as the production laptops end users were issued. So, in the end I stopped giving out loaners completely, and just reassigned end users new assets when their Mac had issues. This meant zero downtime for the end user, no hassle of bringing it back, and our asset management system could track everything tied to that user, and we had the JSS to back up what user owned what laptop, or what user logged into what laptop last.
In my experience, if at all possible, just issue a new laptop and keep the old one to refill your loaner stock. Of course there were cases of end users that kept very good care of their laptops and requested they get their original back. When that happened IT, of course, honored that request and the loaner issued was traded back in. I would say 95% of users did not ever want to trade their loaner back in for their original. So, we simply stopped doing it. Too much of a hassle, and it was also interrupting our end users to take time out of their day to head to IT to swap their loaner back.
Of course all Orgs will have different cultures, processes, ideas, etc. So, take my experience with a grain of salt. For my last job though, loaners were just such a hassle that I stopped doing it and just reassigned hardware when that happened.
Now, in the event that someone needed to borrow a set of laptops for something specific, we had a laptop cart you could check out. Like if we had visitors come look at our laptop program and want to experience it, or if a classroom needed more laptops for a project, or whatever reason, we had a cart you could check out and take with you. Then turn it back in when you were done. We also had the option for individuals to check out a couple of laptops, and they would sign for them and drop them off when they were done.
Cheers,
Tom
  • December 29, 2014
I was hoping a discussion like this would come up on JAMF. Two weeks ago I was doing a JumpStart where the IT Department just received an Arabic Mac Book Pro so we were using that as our target test machine (later nuke/pave for the intended faculty). It's the worst thing I have EVER experienced (besides 10.7 and learning "natural scrolling"... but that is another story or something that @charles.edge would still complain about).
After typing for 10 seconds I stated outloud "You should keep this and have it as your loaner. NOBODY would want to keep it".
The width difference in the Return key and the left shift key are killers: http://support.apple.com/en-us/HT201794
- Justin
emily
  • December 29, 2014
We've been investigating CrashPlan for a few of our teams that want automated backups… I've heard some good things about it.
I think I'm less concerned with true replacements and more concerned with just loaners for folks that left their computers at home. We're a mixed bag environment (MacBook Pros, Retinas, and Airs, Dell 14" and 15" Latitudes) so having a true replacement for every user type is pretty much impossible because we don't have that kind of stock. I was planning on using Macs for loaners because it takes me about 20 minutes to get one going, rather than like half a day like the Windows machines…ugh…
  • December 29, 2014
Sort of off topic here, but I have noticed a lot of orgs are changing their helpdesk to be more of a Apple Genius bar type setup. This has greatly interested me over the past couple years and I have been tinkering with tools I build that are not for end users, but rather level I techs and helpdesk people.
So, lets assume a user has an issue with their OS. Let's also assume they have a valid crashplan back up (that is verified). They take their Mac with the flashing question mark to the helpdesk depot at their office. With Casper Imaging you can reimage an entire computer in under 3 minutes with TDMI and Thunderbolt cables. I did a POC with a customer not too long ago that was just a simple launchd, an asr script and a TDM Thunderbolt connection. We were automatically imaging systems with an 80gig image (lots of extra content) in right around 3 minutes and 30 seconds. Now you could expand on this idea, and leverage Casper imaging with a local DP at a help desk depot, and you could completely restore the user's laptop, start their crashplan recovery and send them on their way with in probably 10 minutes or so. With a brand new OS and all their apps. I know this doesn't necessarily relate to issuing spares, but in this event you could fix their laptop quickly over issuing a spare over the span of time it takes to repair.
I've been very interested in leveraging the Casper Suite to build tools for IT staff as well as end user solutions. I have worked with a few orgs that are setting this type of experience up and so far all of them have positive feed back on these things. Even when I worked at the school district we had sort of a Genius Bar setup like an Apple store. I had tables and users could come into my office and sit down and get assistance. I was building tools back then as well, but they were just automated ways of doing tasks I had to do on a regular basis.
Now, I am looking at writing interactive scripts that allow IT techs to run diagnostics, tasks, and maintenance not only through Self Service, but also through the terminal. I think there are lots and lots of things we can do as Casper Admins to not only build great end users experiences for our end users, but also everyone else in IT.
As for the situation where someone forgot their laptop at home, we had a cart of laptops that people could check out for the day. For the situation of break/fix we just issued a new laptop from our spare stock. If the end user wanted their original Mac back when it came back from repair we honored that as well. We basically just gave them choices and they got to pick what they wanted to do. For the most part I think everyone liked that workflow.
-Tom
acodega
  • December 30, 2014
Awesome input as usual @tlarkin
Self Service can be an awesome tool for IT techs as well as traditional users.
Chris_Hafner
  • December 30, 2014
@tlarkin I couldn't agree more. We are always working to create a comfortable, respectful and helpful help desk experience. The last thing we want is users to dread coming and asking for help, at any level. Thankfully our help desk tech creates most of that environment on her own. That said, having the ability to create quick diagnostic and repair policies for our IT staff really helps out front! It also gives a great structure for permanently fixing whatever issue it was you had to create the policy to resolve. I only wish we had more space to put in tables for my help desk and users to work at instead of the window we have. Fortunately I have a few in my office when things get really bad.
Regarding loaners again; proper staging and planning for your environment is KEY. As our community lives, learns and teaches with these units, transitional speed to a loaner during repair is really critical. I couldn't really keep a faculty member for even 10 min while they are teaching. Often times when something is really bad they simply send a student with their computer to the help desk. Said student has no access to the faculties accounts, let alone a good description of the issues at hand. That wouldn't even count emergency needs by our Board or other visiting dignitaries, teachers and other such professional folks. This is the primary reason we keep pre-imaged loaners on hand at all times even with our network imaging process in at about the 5-10 min mark depending on image configuration.
Beyond that our students are BYOD and our faculty/staff/etc are planned purchases but not always identical. Fortunately we've sorted out any integration and compliance issues by maintaining a community understanding that our loaners are meant to be flexibly assigned to ANY user regardless of need. Because of our purchase planning and turnover we're almost always able to keep our professional users in machines newer than the loaners anyways (under 3 years). So, while we have policies and documents in place to force compliance we almost never have to.
Out of our 30 total loaners we usually only set aside 5 for faculty/staff which run to about 260-ish assigned units. Thanks to our own internal policies and things like the Casper suite and tools developed like @tlarkin mentioned at the help desk, this has become a very happy place for stressed users to come. The reason we set aside 25 for students has more to do with the fact that they drop them far more often than the faculty and often wait until just before or just after a school break to bring them in. It gets interesting when you have half a dozen or more students, with smashed screens, 30 min before they have to leave for the airport on a school vacation, and one help desk tech.
@emilykausalik the neat thing about Crashplan is that it's platform independent so it's probably easier to transfer a users files from PC to Mac than it is trying to explain how to use it. JAMF and the folks from Code42 have a few things going on the corporate side so I'd ask around. We've been working with Julia from Code42s Minn. office and she's been great! @tlarkin with pre-imaged computers (our helpdesk maintains our loaner fleet regularly) the hand off with a crashplan backup could be about a minuet. That's where we're hoping to get. We're still testing and won't yet be bringing the Crashplan storage on site just yet
  • December 30, 2014
Hey @Chris_Hafner
Sounds like you all are building a pretty sound workflow for your help desk. I dig it! Keep up the good work.
@adamcodega
I have always been a fan of Self Service with IT policies scoped by LDAP groups, and also tons of tools/scripts in Netboot Images techs could leverage. I used to build Diskwarrior, Tech Tool, ASD, and a bunch of customer diagnostic/repair scripts in my NetBoot image so techs could NetBoot and run those tools to help troubleshoot/fix computers with issues.
-Tom
  • January 2, 2015
I set up our Macs bound to AD with Centrify. Just finished deploying CrashPlan ProE before the holiday break. So if any of our staff has a system/drive failure or their MBP is stolen, we can provide a loaner.
The person simply logs in with his/her AD credentials and can access their files via the CrashPlan web interface while I set them up with a new MBP with a full-restore from CrashPlan.
- Corbin
Chris_Hafner
  • January 5, 2015
@corbin3ci Nice! That's what I'm talking about!
  • April 29, 2015
@tlarkin you wrote
I used to build Diskwarrior, Tech Tool, ASD, and a bunch of customer diagnostic/repair scripts in my NetBoot image so techs could NetBoot and run those tools to help troubleshoot/fix computers with issues. Where can one learn how to do this with Yosemite tools? I have exactly this need.
I used to be able to make NetBoot images years ago but these days when I try it I always get some sort of cryptic error messages. I can build great "Utility boot drives" on USB, but have been unable to convert one of those into a NetBoot Image. NetInstalls are fairly easy, but for me NetBoot hasn't worked for years.
Chris_Hafner
  • April 29, 2015
Really? While I end up using AutoCasperNBI in general... because it's easy and I can do other things instead, I've been manually building diagnostic NBIs for years without issue (All the way through 10.10.x). If you ever want to troubleshoot, let me know.
RobertHammen
Forum|alt.badge.img+29
  • April 29, 2015
PKGs and AutoCasperNBI for me, always found System Image Utility to be... "flaky"/inconsistent in behavior. Plus the NBI's that AutoCasperNBI have a lot of things (diskless, NFS) set by default, compared to the resultant ones from SIU...
bentoms
Forum|alt.badge.img+35
  • April 29, 2015
@yeldarb Now is a great time to try out AutoCasperNBI as I just released version 1.2.0.
@Chris_Hafner & @RobertHammen thanks for the cheerleading gents!
