Apple Configurator 1.2 Update Available
  • October 10, 2012
  • 16 views
Forum|alt.badge.img+15
Yesterday Apple released an Apple Configurator update. Here is a listing of changes:
This update improves overall stability and performance, and includes the following:
  • Support for new iOS 6 features (Lock to App and Global HTTP Proxy) on supervised iOS devices
  • Support for these new iOS 6 restrictions on a supervised device: Allow the removal of apps from the device Allow use of iMessage Allow access to iBookstore or the purchase of books classified as "Erotica" from iBookstore Allow filtering of profanity for Siri Allow use of Game Center Allow the installation of new configuration profiles
  • Improved reliability when activating a new iPhone or iPad with Wi-Fi + Cellular
  • The last settings used on the Prepare pane are retained when Apple Configurator is quit and relaunched
  • Improved ability to update or restore devices that are currently in recovery mode
  • Members of Active Directory groups are now shown in the Assign pane
  • Paid apps from the App Store can now be installed in the Prepare pane only when a device is being supervised
  • Support for configuring advanced network options on Apple TV
1 reply
  • October 10, 2012
Be careful if you do this update and have scripts that backup the data, the data is moved. From our best guess just looking at it so far it puts it in ~/Library/Containers/. So if you have scripts to back it up which we were actually just writing this morning when we realized the data had moved on one computer and not the one we hadn't run the update on, you may need fix those scripts.
