Adding in additional DNS server and Search Domains
  • March 5, 2012
  • 7 replies
  • 69 views
I've been tasked with implementing this change on some remote users. I've had a quick scout around and can't see an easy way of doing this. Anyone got any ideas?
Best answer by rockpapergoat
do these hosts use dhcp? if so, add them to your dhcp server config, and you won't need to touch the clients.
if they're assigned static IPs, you can use /usr/sbin/networksetup to do the job. i wouldn't go that route unless it's the only option.
  • March 5, 2012
  • March 5, 2012
Thanks. Makes total sense just need to speak to their comms guy now.
Forum|alt.badge.img+20
  • March 5, 2012
Here is the script I use:
# Output: Setting Search Domains #
# Do Not Modify Below This Line  #
/usr/sbin/networksetup -setsearchdomains "Ethernet" "yourcompany.com" "sub.yourcompany.com"
/usr/sbin/networksetup -setsearchdomains "Ethernet 1" "yourcompany.com" "sub.yourcompany.com"
/usr/sbin/networksetup -setsearchdomains "Ethernet 2" "yourcompany.com" "sub.yourcompany.com"
/usr/sbin/networksetup -setsearchdomains "Airport" "yourcompany.com" "sub.yourcompany.com"
  • October 16, 2013
I am trying to add multiple search domains to the Ethernet and Wi-Fi adapter. Here are the scripts that I am using - if I do this on the local client it works great, but once I created a script inside jss and created a policy to run that script I get an error
sudo -a -networksetup -setsearchdomains "Ethernet" domain1.edu domain2.edu domain3.edu
sleep 1
sudo -a -networksetup -setsearchdomains "Wi-Fi" domain1.edu domain2.edu domain3.edu
Am I missing something in the script that I created in jss in why this isn't working?
  • October 16, 2013
my guess is there is not a -a option for sudo.
and -networksetup is not an option it is a command that should not have the - so remove -a - from those lines and something more useful might happen.
Also if you are running through the JSS then its already running as root so you dont need sudo at all.
  • October 16, 2013
Thank you thank you thank you nessts - those tips worked.
  • June 6, 2023
Thank for this - I ended up reworking it for our needs to include DNS servers as well / had to make a minor adjustment for systems with a single Ethernet interface but that was pretty easy once the dual interface systems test proved positive results:
primary_dns="X.X.X.X"
secondary_dns="X.X.X.X"
tertiary_dns="X.X.X.X"
services=("Ethernet 1" "Ethernet 2" "Wi-Fi")
for service in "${services[@]}"; do
/usr/sbin/networksetup -setdnsservers "$service" "$primary_dns" "$secondary_dns" "$tertiary_dns"
/usr/sbin/networksetup -setsearchdomains "$service" "searchdomain1.com" "searchdomain2.com"
done
just swap in your DNS server addresses and Search Domains for the place holders and scope this to any dual ethernet  systems
For single Ethernet  systems the adjustment is:
services=("Ethernet" "Wi-Fi")
It is really that simple
Tested this on macOS 10.15 through 13.3 systems and it works
If you are not sure about the network interfaces on a given target system - remote in (if you are able to) and run the following in Terminal.app
networksetup -listallnetworkservices
