Can't Remove Blur from Pre-Login Wallpaper
  • June 12, 2018
  • 5 replies
  • 19 views
I'm using a script that creates the pre-login wallpaper and saves it as com.apple.desktop.admin.png in /Library/Caches
The script:
1. Takes a source image (installed to each Mac via PKG)
2. Grabs the Mac Screen resolution via the system_profiler command
3. Using sips, resizes the image and saves this into /Library/Caches with the appropriate name
4. Resets ownership and permissions on the file
(Full script is available if necessary, or if you'd like to use it for your own purposes)
This process works, however at the login screen the wallpaper is shown as blurry. I've discovered that if I open this generated image using 'preview' and then just click save the blur is removed when I next log in.
Does anyone have any ideas what I might be missing with sips that mustn't be generating the image in a format macOS expects. The base template image was created in Photoshop and saved as a png.
Thanks
Ryan
Best answer by __Uss
you have done everything correctly, however, the image needs to be saved as a Transparent PNG. It can be done via photoshop or preview on the mac.
  • June 12, 2018
  • June 12, 2018
Thanks @__Uss , I'll give that a try and let you know how it goes.
  • June 12, 2018
Hi @__Uss
Your suggestion has resolved my issue.
Thanks for your help!
  • June 13, 2018
Hi @rypowell88 ...
Would you mind posting the script?
  • June 17, 2018
Hi @sdmike
I have a Github where I save copies of my scripts. The wallpaper one is here: https://github.com/rypowell1988/mac-management/blob/master/SetDefaultWallpaper.sh
Thanks
Ryan
