Updated FileVault 2 status check Extension Attribute now available
  • January 9, 2015
  • 6 replies
  • 61 views
Forum|alt.badge.img+33
I've updated my FileVault 2 status check EA, to better handle Macs with multiple encrypted volumes. I'd noticed that I was occasionally seeing some Macs reported by the EA as being FileVault 2 encrypted, but on investigation, the encrypted drive was actually a non-boot volume (like an encrypted Time Machine backup.) I've addressed the issue by having the EA check specifically for the boot drive's FileVault 2 status.
The updated EA is available from the following address:
https://github.com/rtrouton/rtrouton_scripts/tree/master/rtrouton_scripts/Casper_Extension_Attributes/filevault_2_encryption_check
  • January 9, 2015
Thanks Rich!
  • January 9, 2015
Works great! Thanks Rich!
  • January 9, 2015
Merci rich
  • January 9, 2015
Thanks Rich, where do I send the bitcoin to? ;)
  • August 2, 2018
Hey @rtrouton - I've been using this great script for a while, but we're now not getting a correct boot partition FV2 status reported for partitions in MacOS 10.13. Any chance you know how this could be updated for High Sierra?
  • April 7, 2021
@rtrouton Is there an updated script available to include Big Sur? Getting "Unknown Version Of macOS"
