I recently built a Netboot server to image the computers in my environment. My Netboot image was created using AutoDMG and AutoCasperNBI. I use prestage imaging configurations based on serial number so the imaging process is as automated as possible. On a brand new Mac, imaging works as expected with no issues. However when reimaging an existing Mac, I often run into issue where the Netbooted OS asks for a password to unlock the internal "Macintosh HD". This is because all of our Macs are encrypted via Filevault 2.
I thought the "Local Account" section in the Install payload for the prestage configuration would unlock the encrypted drive so the imaging process could run with minimal interaction but that doesn't seem to be the case; Casper Imaging always errors out, I have to manually type the password in, delete the computer from inventory, flush the prestage config logs, and launch Casper Admin again for it to work.
Does anyone have any tips on being able to image a previously encrypted Mac without manually typing a password in to unlock the drive?
