API GET function only returning one Record in JSON response body
  • January 12, 2015
  • 5 replies
  • 52 views
XML seems to return data from my report just fine, but JSON (which I'd prefer) does not. I'm trying to consume data from this report in a 3rd party SaaS application and this is proving troublesome. This behavior is consistent across the board in JAMF, my consuming application (ServiceNow) and Postman chrome plugin.
Disclaimer: I'm not a JAMF admin, so I'm not sure what data might be relevant to post here.
external image link
Best answer by admin13
@mglenn
If it doesn't, please let us know either here or by getting in touch with your Technical Account Manager. You can do that by giving Support a call, sending an e-mail to support@jamfsoftware.com (it gets routed directly to their case queue), or by using the My Support section of JAMF Nation.
Amanda Wulff
JAMF Software Support
  • February 27, 2015
So you're saying that the "/computers" API isn't returning JSON data? If so, i'm having the same problem. What version of JSS are you running? I'm on 9.52.
Thx,
Adam
  • February 27, 2015
@mglenn @arschebl
We had an issue (D-008354) in versions of the JSS prior to 9.65 that caused the output from XML to differ from the JSON output; in those cases, we’d see essentially what’s shown in the screenshots here: JSON output would return partial data, whereas XML would return a full set of data, as expected.
This issue was fixed as of 9.64.
Amanda Wulff
  • February 27, 2015
We're currently running 9.62. Our admin is going to request an upgrade to 9.65. Hopefully that fixes the issue
  • February 27, 2015
@mglenn
Amanda Wulff
  • March 6, 2015
Upgrade to 9.65 resolved this for me. Thank you very much
