JSS REST API C# example?
  • March 4, 2016
  • 6 replies
  • 69 views
Does anyone have working JSS REST API code in c#? I am trying to write an application that can grab basic computer information but I cannot find any good examples of C# and REST API.
If you have any sample code, sharing is greatly appreciated.
Thanks.
Edit:
I figured it out.
  • March 6, 2016
How about sharing. I would be interested too :-)
Regards
Graeme
  • November 19, 2018
@Graeme Sorry it took so long, for some reason I never saw your request.
        public class Casper
            public string casperUsr = GlobalVar.CasperUsername;
            public string casperPaswrd = GlobalVar.CasperPassword;
            public bool computerExist = false;
            public bool computerDeleteSuccess = false;
            public bool computerCreateSuccess = false;
            public string confirmMessage = "";
            public string macDTMUrl = "https://<your URL>:8443/JSSResource/computers/name/";
            public string macDTMUrlAdd = "https://<your URL>:8443/JSSResource/computers/id/0";
            public string macDTMUrlAddPath = "JSSResource/computers/id/0";
            public void GetCasperInfo(string computerName)
                var client = new RestClient(macDTMUrl + computerName);
                client.Authenticator = new HttpBasicAuthenticator(casperUsr, casperPaswrd);
                var request = new RestRequest(Method.GET);
                request.AddHeader("content-type", "application/x-www-form-urlencoded");
                IRestResponse response = client.Execute(request);
                if (response.StatusCode == HttpStatusCode.OK)
                    computerExist = true;
                    //MessageBox.Show("OK Was recevied");
                else if (response.StatusCode == HttpStatusCode.NotFound)
                    //MessageBox.Show("Not Found Received");
                else if (response.StatusCode == HttpStatusCode.Unauthorized)
                    MessageBox.Show("Your account lacks sufficient privleges: " + response.StatusCode);
                    MessageBox.Show("Unhandled Error: " + response.StatusCode);
            public void DeleteCasperComputer(string computerName)
                var request = new RestRequest(Method.DELETE);
                    //MessageBox.Show("OK on Delete recevied");
                    computerDeleteSuccess = true;
                    MessageBox.Show("Computer not found so it could not be deleted");
            public void addComputer(string computerName, string MACAddress, string serialNumber, string siteID)
                string addString = "<?xml version ="1.0" encoding="ISO-8859-1"?><computer><general><name>" + computerName + "</name><mac_address>" + MACAddress + "</mac_address><serial_number>" + serialNumber + "</serial_number><site><id>" + siteID + "</id></site></general></computer>";
                RestClient client = new RestClient(macDTMUrlAdd);
                RestRequest request = new RestRequest(Method.POST);
                request.AddHeader("content-type", "application/xml");
                request.AddParameter("application/xml", addString, ParameterType.RequestBody);
                if (response.StatusCode == HttpStatusCode.Created)
                    computerCreateSuccess = true;
                    MessageBox.Show("Add computer failed: " + response.StatusCode);
            public void Message()
                confirmMessage = "Casper: ";
                if (computerExist && computerDeleteSuccess)
                    confirmMessage += GlobalVar.computerName + " has been removed from Casper " + Environment.NewLine;
                else if (computerExist && !computerDeleteSuccess)
                    confirmMessage += GlobalVar.computerName + " could not be removed from Casper " + Environment.NewLine;
                    confirmMessage += GlobalVar.computerName + " was not in Casper" + Environment.NewLine;
  • November 20, 2018
Many thanks
  • November 26, 2018
@Graeme You are welcome. I actually had to update it last week to use TLS 1.2 explicitly because we upgraded to 10.8. Here is the new code:
        public class Casper
            public string macDTMUrl = "https://<your url>:8443/JSSResource/computers/name/";
            public string macDTMUrlAdd = "https://<your url>:8443/JSSResource/computers/id/0";
                ServicePointManager.SecurityProtocol = SecurityProtocolType.Tls12;
                string addString = "<?xml version ="1.0" encoding="ISO-8859-1"?><computer><general><name>" + computerName + "</name><mac_address>" + MACAddress + "</mac_address><serial_number>" + serialNumber + "</serial_number><site><id>" + siteID + "</id></site></general><extension_attributes><extension_attribute><id>68</id><name>BuildComputerName</name><value>" + computerName + "</value></extension_attribute></extension_attributes></computer>";
                //string addString = "<?xml version ="1.0" encoding="ISO-8859-1"?><computer><general><name>" + computerName + "</name><mac_address>" + MACAddress + "</mac_address><serial_number>" + serialNumber + "</serial_number><site><id>" + siteID + "</id></site></general></computer>";
                    MessageBox.Show("Add computer failed: " + response.StatusCode + " response message " + response.ErrorMessage + "response content" + response.Content);
  • November 26, 2018
Thanks again.
  • August 9, 2023
Here is the code I'm using to retrieve data from jamf in c# public async void button1_Click(object sender, EventArgs e) { var JamfDataRetriever = new JamfDataRetriever(); List<DevFromJamF> managedJamfInventoryDevices = await JamfDataRetriever.GetJamfDevices(); } public class JamfDataRetriever { static HttpClient client = new HttpClient(); private static HttpClient sharedClient = new() { BaseAddress = new Uri("https://myServer.jamfcloud.com"), }; public async Task<List<DevFromJamF>> GetJamfDevices() { string urlT = "https://myServer.jamfcloud.com/api/v1/auth/token"; string url = "https://myServer.jamfcloud.com"; string authEndpoint = "/uapi/auth/tokens"; string uName = "apiaccessAccount"; // string pWord = "ApiAccessPassword"; // string r = string.Empty; //------------------------------------------------------------------------------------------------------------ var content = new StringContent("", System.Text.Encoding.UTF8, "application/json"); client.DefaultRequestHeaders.Authorization = new System.Net.Http.Headers.AuthenticationHeaderValue( "Basic", Convert.ToBase64String(System.Text.Encoding.ASCII.GetBytes($"{uName}:{pWord}"))); // Send the POST request HttpResponseMessage response = await client.PostAsync($"{urlT}", content); // Check the response status string token = ""; string expires = ""; if (response.IsSuccessStatusCode) { // Request was successful string responseBody = await response.Content.ReadAsStringAsync(); // Parse the JSON response JsonDocument jsonDocument = JsonDocument.Parse(responseBody); JsonElement root = jsonDocument.RootElement; // Extract the token value and expiration date token = root.GetProperty("token").GetString(); expires = root.GetProperty("expires").GetString(); Console.WriteLine("Token: " + token); Console.WriteLine("Expires: " + expires); } else { // Request failed Console.WriteLine("Request failed with status code: " + response.StatusCode); } //------------------------------------------------------------------------------------------------------------ if (token == "") { token = "7u_Rt_Sg986ScVGYRdU"; // for testing } string? bearerToken = token; string sections = "GENERAL,HARDWARE,USER_AND_LOCATION, OPERATING_SYSTEM"; //sections= ###Supported Values are: GENERAL, DISK_ENCRYPTION, PURCHASING, APPLICATIONS, STORAGE, USER_AND_LOCATION, CONFIGURATION_PROFILES, PRINTERS, SERVICES, HARDWARE, LOCAL_USER_ACCOUNTS, CERTIFICATES, ATTACHMENTS, PLUGINS, PACKAGE_RECEIPTS, FONTS, SECURITY, OPERATING_SYSTEM, LICENSED_SOFTWARE, IBEACONS, SOFTWARE_UPDATES, EXTENSION_ATTRIBUTES, CONTENT_CACHING, GROUP_MEMBERSHIPS HttpClient inventoryRequest = new HttpClient(); inventoryRequest.DefaultRequestHeaders.Add("Authorization", "Bearer " + bearerToken); inventoryRequest.DefaultRequestHeaders.Add("Accept", "application/json"); HttpResponseMessage responseInv = await inventoryRequest.GetAsync($"{url}/api/v1/computers-inventory?section={sections}&page=0&page-size=1000"); // Check the response status if (responseInv.IsSuccessStatusCode) { string responseBody = await responseInv.Content.ReadAsStringAsync(); // Parse the JSON response JsonDocument jsonDocument = JsonDocument.Parse(responseBody); JsonElement root = jsonDocument.RootElement; // Get the computers array JsonElement computers = root.GetProperty("results"); TibsDbContext curContext = new TibsDbContext(); curContext.Database.ExecuteSqlRaw("TRUNCATE TABLE DevFromJamF"); int i = 1; using (var _db = new TibsDbContext()) { foreach (JsonElement computer in computers.EnumerateArray()) { JsonElement general = computer.GetProperty("general"); JsonElement remoteManagement = general.GetProperty("remoteManagement"); JsonElement hardware = computer.GetProperty("hardware"); JsonElement userAndLocation = computer.GetProperty("userAndLocation"); JsonElement operatingSystem = computer.GetProperty("operatingSystem"); string computerName = general.GetProperty("name").GetString(); string userName = userAndLocation.GetProperty("username").GetString(); string versionOS = operatingSystem.GetProperty("version").GetString(); string serialNumber = hardware.GetProperty("serialNumber").GetString(); string lastContactTime = (general.GetProperty("lastContactTime").GetString()); DevFromJamF newDevFromJamF = new DevFromJamF(); newDevFromJamF.Host = computerName; newDevFromJamF.Username = userName; newDevFromJamF.Osfull = versionOS; newDevFromJamF.SerialNo = serialNumber; if (lastContactTime != "" && lastContactTime != null) { newDevFromJamF.LastCheckIn = DateTime.Parse(lastContactTime); } _db.DevFromJamF.Add(newDevFromJamF); _db.SaveChanges(); } } } else { Console.WriteLine("Error: " + (int)response.StatusCode + " " + response.ReasonPhrase); } return new List<DevFromJamF>(); }
