Is there a direct download available for "OS X Yosemite Recovery Update 1.0"?
  • April 30, 2015
  • 4 replies
  • 6 views
I searched Apple's website for a download but came up empty handed. Does anyone know if there is one available? If there is not, is there a way capture the download from the app store?
Best answer by RobertHammen
softwareupdate -d on a Machine that requires the update, will download it to /Library/Updates.
  • April 30, 2015
If you are running an in-house ASUS server you can dig into the file store and get the package. I havent tried running it this way, as ASUS deals with it fine enough for me.
RobertHammen
Forum|alt.badge.img+29
  • April 30, 2015
scottb
  • April 30, 2015
Yes, this is a good post for this Download Updates Only
  • May 1, 2015
Thanks for the help!
