Mavericks Netboot Fail with MacBookPro8,x
  • April 4, 2014
  • 41 views
seanhansell
I built a NetBoot image using OS X 10.9.2 on a MacBookPro11,1 and am serving it out with a OS X 10.8 Mountain Lion Server. Whether served over NFS or HTTP, the machine fails to boot any MacBook Pro (Early 2011). It works flawlessly on every other machine / model including the MacPro6,1.
No errors appear in the NetBoot Service Log. The following error appears in a verbose boot log: "error loading kernelcache (0x7)".
I found a previous discussion on JAMF Nation about this error where there was a checksum issue on the kernelcache file. I've already confirmed that my MD5 hash matches the copy on the server with the original NetBoot capture using System Image Utility.
HALP?
bentoms
Forum|alt.badge.img+35
  • April 4, 2014
Have a look at the following thread, especially the linked script & 32MB kernelcache.
https://jamfnation.jamfsoftware.com/discussion.html?id=9836
  • April 4, 2014
@bentoms is correct, the issue is due to the kernelcache. That thread has instructions to fix this issue.
  • April 4, 2014
Yep..... worked for me also.... drove me nuts.
