Need help getting Custom Applications reports
  • February 10, 2011
  • 0 replies
  • 0 views
Hi All,
I am trying to pull a Application Inventory report for almost 100 Macs so I have included them in the inventory save searches. And then from the View Results As I am choosing Application Distribution Report(PDF) which is showing a Multipage PDF report for applications which is not a easy to read or upderstant report and have lots of unwanted details which is not use full.
I am looking for an custom report which should shows the applications which is in the /Applications Folder and easy to understand. Is anyone faced this kind of problem? What would be the solution to get exactly what is in the Applications folder?
Regards,
Vinay Washimkar
