Has anyone experienced this problem before?
I basically was trying to install a wildcard cert for tomcat, but this failed so revert my server.xml file to the original
But for some reason I can not web to 8443.
Tom cat is on port 8080 and this works, but cant get to 8443
I'm using Casper Suite 8.22 if thats any help
Thanks
Abz
