#JNUC Killer Ninja Script Monkey 101: Introduction to Bash Scripting
  • October 19, 2012
  • 7 replies
  • 53 views
Forum|alt.badge.img+23
Miles Leacy and Tom Larkin will be presenting this session on Tuesday, Oct 23 at 3:45 pm. Dowling Studio (level 9)
This session is intended for administrators who are new to scripting and would like to find out what it's all about and how to get started. Those already familiar with the basics may be interested in the other scripting session: Script Dojo: Bigger, Better, Faster, More! in Nelson Classroom (level 8) on Wednesday, Oct 24 at 1:00 pm.
For everyone who will be in the audience (and everyone who would like to but can't make it), let's use this thread to collect thoughts/ideas/links/questions.
Here are some handy links related to the presentation:
bash Reference Manual at gnu.org:
http://www.gnu.org/software/bash/manual/bashref.html
bash Shortcuts at ss64.com:
http://ss64.com/bash/syntax-keyboard.html
Link to session schedule and descriptions:
http://www.jamfsoftware.com/events/user-conferences/jamf-nation-user-conference-2012/sessions
  • October 19, 2012
What do we mean by the basics?
  • Terminal Basics
  • Anatomy of a Script
  • Standard Output
  • Working With Variables
  • Pipe
  • Binary Toolbox - a brief discussion of useful binaries
  • Dissection of Sample Scripts
  • October 24, 2012
During today's session, Tom had a script with commands pulling the actively logged in username. Is there a way to automatically use this information to add them to a group? His particular example was adding to the LPAdmin group, though my interest is using this for the Developer group. This would help non-admin users (ie students) use XCode without having to use admin credentials. Has anyone tried this? It's my understanding that their group membership would allow them to use XCode without admin credentials.
stevewood
Forum|alt.badge.img+38
  • October 24, 2012
The group has no play on the basics of the script. Simply change "_lpadmin" to "developer" and voila you've got what you need. To do what you're asking, to add the current logged in user to the developer group, you can do something like this:
# get current user
CurrentUser=`ls -l /dev/console | awk '{ print $3 }'`
#add current user to _developer group
dseditgroup -o edit -a $CurrentUser -t user _developer
Set that up to run at login via a launchd item, once per user, and you've got what you need.
Make sense?
Steve
  • October 24, 2012
@dgraham125
You have to have "DevToolsSecurity -enable" as well.
Here is our login script.
# With Casper if you use $3 in a script @ login, $3 will be the username of the user logging in
loginUsername="$3"
# Prevent non-admin users (students) get prompted for admin credentials by adding logging in user to _developer group
/usr/sbin/dseditgroup -o edit -a $3 -t user _developer
# Enable Xcode “Developer Mode”
/usr/sbin/DevToolsSecurity -enable
Forum|alt.badge.img+31
  • October 24, 2012
Hi Everyone,
Due to this being such a popular topic, I think more popular than some of us anticipated, I am going to try to get into some of the Overtime sessions today after our second presentation. There are two OT sessions on the 8th floor of the Gunthrie. If you have any more questions on our presentation find me during those sessions. It looks like there are two one at 2:15PM and one at 3:15PM. I am going to try to be at both.
Thanks,
Tom
  • October 25, 2012
Hey All,
Thanks to all of the attendees who made this session a success. Tom and I have heard from many of you and we're very glad to have brought you some useful information and techniques. Due to the overwhelming demand for these two scripting sessions, you can be sure that we'll be bringing even more content your way the next time we all get together!
As promised, here are some resources from and to expand on the session...
Boot Volume Free Space Extension Attribute
https://jamfnation.jamfsoftware.com/viewProductFile.html?id=135&fid=583
Here's the same script without the XML wrappings:
# Returns the free space on the current boot volume in GB, rounded down to the nearest integer.
free=`diskutil info /|grep "Free Space"|awk '{print $4}'`
echo "<result>"${free%.*}"</result>"
Variables
Setting a variable:
var="hello JNUC 2012!"
Expressing that variable
$var
sudo
Without root privileges, you can't do this...
ls /private/var/root
But with sudo, you can
sudo ls /private/var/root
Create a file or update the modification date of an existing file
touch ~/Desktop/myfile.txt
Delete a file
rm ~/Desktop/myfile.txt
Get hardware and software information
Lots of info
system_profiler
What categories are there?
system_profiler -listDataTypes
Display just one category
system_profiler SPHardwareDataType
Catchall for reporting on and/or changing many system settings
systemsetup
Catchall for reporting on and/or changing many network settings
networksetup
Command line version of Disk Utility
diskutil
Finding a term within a file or set of output
In a file...
grep "Some Term" textfile.txt
From the output of another command
diskutil list | grep "Recovery"
Using the print function in awk
http://themacadmin.com/?p=449
Directory Service command line utility
List the UniqueID attribute of all local user accounts
dscl . list /Users UniqueID
List the members of the "admin" group
dscl . read /Groups/admin GroupMembership
Reading and settings system and application preferences
Write a value to a preference key
defaults write ~/Library/Preferences/com.apple.dock orientation left
Read the value of a preference key
defaults read ~/Library/Preferences/com.apple.dock orientation
JAMF Binary
List all verbs
jamf help
List options for a verb
jamf help recon
JAMF Helper
Path to JAMF Helper
/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper
JAMF Helper Usage Help
/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -help
one liners
Find Current User
Create a new line in a file from the output of a command
echo "some string" >> ~/Desktop/myfile.txt
  • October 25, 2012
Hi everyone,
There is another OT session at 2:15 on floor 8. I'm going to head down there if you'd like to ask any more scripting questions
Thanks
Tom
