Hello
Anyone unable to add location information such as department and building for users that own multiple devices in JSS 9.3? To clarify I have some users that own or use more than one system me included. I am unable to add department and building for more than one system owned by that user. This was fine in 9.25 and before. After upgrading to 9.3 I am unable to do this. If I do edit one devices location information it removes it from the other owned by that user. I tried the database repair and checked tables, etc.. I stopped Tomcat before running the repair. Maybe it is nothing, maybe it supposed to work this way, maybe it is a bug in 9.3 or maybe it is my DB acting up.
to clarify: A user with multiple devices I am unable to add Department or Building to their other devices successfully. The information will not save it will only save on one device. All other information is present when adding the same user to another device. I am using LDAP to get users information. The departments and buildings are done manually. I do get room info after adding the users from an LDAP query.
I am not over riding the building and department per subnet because I have too many different departments in one subset in some of my locations.
Hope this makes sense.
Anyway I am just reaching out.
Thank you.
