Is it possible to remove the jamfbinary with a script
  • March 16, 2012
  • 11 replies
  • 56 views
I have some machines that need to have the jamf binaries removed as they should no longer be under management. I don't have physical access to the machines, but they are still active in my JSS. Is it possible to create a script with /usr/sbin/jamf removeFramework to do this?
  • March 16, 2012
you should be able to just write a script to run jamf removeFramework and run it through JAMF or ARD (as root)
Forum|alt.badge.img+20
  • March 16, 2012
/usr/sbin/jamf -removeFramework
  • March 16, 2012
Thank you.
  • March 16, 2012
Hmm. I have created the script, set it to executable and uploaded it to my JSS. Ive created a policy to run it, but am getting an error. Any clues
Running Script remove.sh...
Script Exit Code:126
Script Result: sh: /private/tmp/remove.sh: /bin/sh: bad interpreter: Operation not permitted
Unmounting file server...
bentoms
Forum|alt.badge.img+35
  • March 16, 2012
Eric, why not just make them unmanaged in the JSS itself?
  • March 16, 2012
bentoms,
I don't want to leave them with the jamfbinary running in the background. Deleting the machine from the JSS doesn't stop the binary running on the machine does it?
bentoms
  • March 16, 2012
Your right. It keeps the binary.
Do you have any other remote tools? Maybe try running the command via ARD or SSH?
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • March 16, 2012
The binary is just a file. It's not a running process. Casper works by using launchd items to call the binary to do tasks such as checking for new tasks every 15 minutes, hour or however long you've set.
I don't see -removeFramework as an option of /usr/sbin/jamf. That may be why this command isn't working. I don't find this command in the manual either. Or maybe this is just an undocumented feature.
I feel it's a good idea to not leave cruft on machines if you can help it.
Delete the binary:
rm /usr/sbin/jamf
Delete the JAMF launchd items:
rm /Library/LaunchDaemons/com.jamfsoftware.*
Delete the JAMF Applications Support directory:
rm -R /Library/Application Support/JAMF/
Restart.
I think that should do it but others may point out files I've missed.
stevewood
Forum|alt.badge.img+38
  • March 16, 2012
William - it is an undocumented feature. It removes the binary and the cruft. It does leave the /Library/Application Support/JAMF/logs folder, but that should be about it.
Eric - I used the script that Matt posted and was able to remove the framework via Casper Remote (running that script) on a machine with no problems. A bad interpreter error makes it sound like a problem with the system knowing which interpreter to use. A quick Google of that error found several threads talking about 10.7.3 having a quarantine problem:
https://discussions.apple.com/thread/3733470?start=30&tstart=0
Could that be the issue?
Steve
  • March 16, 2012
The bad interpreter error can happen for a number of reasons...I just got it last week because I had a dumb error in a script but for the life of me I can't remember what it was! :P
It can happen if you have Windows line endings on your scripts sometimes.
I am not sure about the extended attributes issues previously reported on as I make it a habit of cleaning all that junk (except for com.apple.ResourceFork) up almost religiously when packaging. Here is a function from my .bashrc to remove a given attribute from all the items in a directory.
rmattr() {
    find . -depth 1 -print0 | xargs -0 xattr -d $1;
usage would be something like:
$ rmattr com.apple.FinderInfo
Whoever found/shared the -removeFramework first thanks a bunch. I used to do this. XD
shopt -s nullglob
toremove=("/Library/Application Support/JAMF"
/Library/Caches/com.jamfsoftware.autorun
/Library/LaunchDaemons/com.jamfsoftware*
/Library/Preferences/com.jamfsoftware*
/System/Library/LaunchDaemons/com.jamfsoftware*
/System/Library/StartupItems/JAMF
/etc/jamf.conf
/etc/scripts
/private/var/root/Library/Preferences/com.jamfsoftware.jamfHelper.plist
/private/var/run/jamf
/usr/sbin/jamf
/usr/sbin/jamfvnc
/var/log/jamf.log
/var/*local_jamf_user*
/var/root/Library/Preferences/com.apple.loginwindow.plist)
for item in "${toremove[@]}"; do
    [[ -e "${item}" ]] && rm -rf "${item}"
done
find /Users -type f -name "com.jamfsoftware.*" -exec rm {} ;
dscl . -delete /Users/*local_jamf_user* &> /dev/null
/usr/bin/osascript << EOF
tell application "Finder"
        activate
        display dialog "Removal of JAMF files complete. Be sure to remove ssh user & pass information from JSS." buttons {"OK!"} with icon caution
end tell
EOF
  • March 17, 2012
Thanks all for your responses. I will give these a try and report back.
